special tools / diagrams ??
Old 19 Aug 2009, 10:50 am
Default special tools / diagrams ??
hey every one , i am here to help out my mom & from reading all the posts/threads i have come to the conclusion its her wheel bearing . she has a 03 4 banger non turbo (if a 4 even comes with a turbo ?)& i an attempting to do this solo . its the front driver side & since im changing the wheel bearing i may aswell do the hub bearing ?? . my question that i have is , is there any special tools needed ??? i did read somewhere that a hub tool is needed ?? will a wheel puller work ?? i have a few diffrent types . also is there a site or does any one have or know where i could see a fairly detailed pic of all this so i can sort of see what im up against befor i start rippin everything apart ???? any help would be greatly appreciated , thanx
Old 19 Aug 2009, 11:44 am
mopar_man's Avatar
Default Re: special tools / diagrams ??
Wheel bearing and hub bearing are the same thing. The bearing is pressed in so I wouldn't even worry about getting a hub puller. Take the whole knuckle into a shop that can press them out and press the new bearing in. There's no special tools involved with getting the knuckle out. If you want the pages out of my service manual for hub removal, I can send them to you in a PM.
1973 Barracuda
340/auto
Modifications: Too many.
2002 PT Cruiser
N/A 2.4L/5-speed
1989 Caprice Wagon
307/auto
Old 19 Aug 2009, 12:00 pm
sure !! , that would be great . any help would help , thanx
Old 19 Aug 2009, 06:59 pm
got the diagrams man thanx alot , that will help out big time .
cheers
Old 23 Aug 2009, 11:11 am
ok , i finaly got this appart & the hub is seased in the stearing knuckle & the actual bearings are pretty chewed up & some are side ways & there is a goug out around the inner part of the knuckle where the bearings ride . i couldnt get to a shop in time yesterday to have them look at it or have them press it out . from what i described would both the hub & the knuckle be garbage ?
Old 23 Aug 2009, 09:03 pm
Chromenut's Avatar
You're probably okay. Still, I'd have someone with the proper press push the new bearings in. Once you get the old out, make sure the inside is smooth and nothing left from the old bearings.
Old 28 Aug 2009, 06:12 pm
one more obstacle ???? ok , she has been with out her car for a while , i know , she has been using mine . i have got everything back together & it went well just the tie rod , when im trying to tighten , it just spins . please is there a way to stop this so i can tighten & get my car back ?? any help or suggestions would be very much appreciated
thanx
Buy special tools JooV General PT Cruiser Discussions 3 06 Nov 2008 01:54 am
Tools required for brake change? scrisp2 General PT Cruiser Discussions 5 06 Sep 2006 09:11 pm
