Ive been eying these Boyd Coddington V-Twin wheels in 18x7. Size-wise they will fit, but the bolt pattern is not specified and the only two backspaces available are 4.00 or 5.25. is either of those useable, or should I start looking for another set of wheels. I posted the link below to see the chart.
Legend V-Twin Pricing |
Did a fast search and the only thing I could find was on PTE (PT Enthusiasts).
Backspace isn't too critical with the PT Cruiser (unless you're trying to fit 15'' alloys) because there is a lot of room in the wheel-wells and fairly decent brake and suspension clearances. There are a lot of PTE running 8" rims (on 17, 18 or 19 inch rims) on their Cruisers with no problems. Most after-market wheels fitted to the Cruiser run offsets between 35-40mm. ...and of course you still have to find out the bolt pattern. The PT Takes 5X100.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. 100,000 miles, Original Owner Visit My Home Page www.CREWZIN.com |
1973 Barracuda 340/auto Modifications: Too many. 2002 PT Cruiser N/A 2.4L/5-speed Modifications: Boogers, Maddog 80% STS, Auto throttle body, Airbox modifications, Eibach Pro springs, Energy Suspension control arm bushings & motor mount inserts, disabled balance shafts. 1989 Caprice Wagon 307/auto Modifications: Lowered 2" front and rear, flat black paint, emblems and trim removed and filled, pinstriping, big 'n little tires. |
Starting with the first one....NO, the GT's come with a freakin 17x6 wheel. Can you imagine that? Try getting tires for that stupid thing! That's why you see so many of us on GT's getting rid of the factory wheels. And no, he was running stock calipers.
On the strut thingy, the distance changes between models of struts. The pan, or spring seat, is even different shape between some of them. I just kind of threw that out there as a generalization. On the last one, yes, you said the same thing I said, only you said it differently. The backside spacing is from the back of the rim to the mounting surface. And I said the same thing, backspacing and offset are different. You got dat right man!! Other than that, yes, I agree with everything you say...lol... |
Yeah but does either of those backspace sizes fit. The 4.00 or the 5.25. Which one brings me closest to stock. And yes, I was think or doing a 1.5 to 2" drop unless the 18's fill out the wheelwells better. And its not a GT or Turbo.
ON my pictures you're looking at a 1.5" drop front, 1.3" drop rear, Tokico Blues, and H&R springs, along with 17" wheels and 215/50's. I went taller tire, same height wheel, rather than taller wheel, shorter/low profile tire. Taller tire, more sidewall, softer. Taller tire, taller wheel, less sidewall, great on turns and at the track, suck on the open road, as in your butt will get tired of them in short time.
As to the backspacing, I bought my wheels by offset, so not sure. Somewhere here in my vast PT library I have a chart on this... I'll see if I can find it... |
Hey their pteezer129,
I just wanted to throw my 2 cents in. Now, I am not nearly as up on backspacing issues per the conversation here so I am afraid I am not much help their. What I do know about wheels is limited but the knowledge obtained was taken from my experience while taking a break from Long Distance Truck Driving, to running a Flatbed for one of the the largest Steel Suppliers in LA who supplied all of the Billit Aluminum to Boyd, KMC, American Racing, and so on of which two of them were on my daily route, and KMC had their Shop next door to the Steel plant I worked out of. As such, I had several good friends I made who cut wheels, and picked up bits and pieces here, and their. So for what its worth... Most aftermarket wheels can be special ordered from the Manufacturer as Blanks (un-drilled), and can then be drilled to spec accordingly to fit most cars bolt pattern wise, so you might be able to order those Boyds, and have them drilled to fit. You can also request specific offset, and so on. You can go as large as 19" wheels on a PT without exceeding the overall dimensions of the stock wheels on a PT size wise, and 20"s will fit in back as well no matter how low you lower your PT. I actually had a 19" / 20" combo test fit on my PT at KMC one day with my 3/5 drop and they actually fit without any issues, but they were way out of my budget even with a heavy discount so I had to let em be. If you have Air Ride, you can go as large as 20"s without modification, however the width of the wheels does play a factor to a certain extent if you want to lower your PT on Air Ride due to clearance issues between the wheels, and front struts not allowing the front end to go all the way down to where it should be. And of course, the biiger the wheels, the less the ride quality, and greater chance your gonna bend a nice shiny wheel on a pothole making for the potential to have a really bad day. Now, I haven't heard about too many aftermarket wheels having such severe issues fitting over stock calipers myself, but like I said, I am not 100% up on it to be able to give a good educated answer either. It just sounds funny to me for some reason. It wouldn't be all that hard to have the wheels tuned to spec on a Lathe, but that beside the case. So, in retrospect, you might have a decent shot at special ordering those wheels cut to your Spec's, and drilled to your PT Either way I would check with several Distributes, as well as see if you can find Rep directly and talk to them. TAsk Questions, Look at all your Options, and then go from their. As Chromenut said, at the end of the day, this is your Ride! DO what you want to it! Just be careful, go easy, go safe, and I'll catch ya later. Candyman
2003 Dream Cruiser Series 2 Serial# 0377: 2.4 HO Turbo. Interior: Orange/Slate 2 Tone Leather: Audio/Video: 3000 watt Clarion/Rockford Fosgate System, 2 DVD's /3 Monitors. Suspension: Air Ride Technologies. Paint: Custom re-Spray: House of Kolor Candy Tangerine Pearl over a Mitsubishi Silver Base Metallic, Basic black Flames, 4 colors Ice Pearl streaked throughout Flame Design, Maroon Drop Shadow, Hand Pin Striped Transition from Red to Orange, and Lots of Clear Paint & Body, Flames, and Audio Layout done by yours Truly! ![]() Certified Auto Detail Specialist. .Certified Paint and Body Tech. .PT Cruiser Fan for Life! ![]() Check out my Custom PT Club Website: http://westvalleyforum.proboards.com/index.cgi And my ever growing PT Photo Archives: http://s458.photobucket.com/albums/q...uiserArchives/ Got a Question? Drop me a line anytime: westvalleycruisers@yahoo.com Last edited by Candyman; 21 Aug 2009 at 10:00 am. |
| Custom Wheels/& Tires! | 1lowufo | Classifieds: For Sale/Trade | 0 | 27 Aug 2006 07:18 pm |
| Colorado Custom Paradox Wheels & Tires | Meeks | Classifieds: For Sale/Trade | 0 | 20 Sep 2003 05:00 am |
