Hi,
I'm just going to change my brake pads & discs/rotors, if you wasnt going to use a clamp to push the pistons in what would you do? |
If you don't have a "C" clamp handy, you can try just pushing the brake pad against the piston to open up enough space for the new thicker pads. First look at the brake fluid container and if it's right to the top you should empty some out so the piston can push out.
Ive got a g clamp but not big enough damn it now its too dark. how snug should the pads be on the disc?
With the caliper back in place with the new pads, the disk should be allowed to rotate without any drag. A very slight scraping noise might be heard. Couple hours of daylight left over here too. (Virginia).
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. Original Owner, 110,000 miles MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a Garage. Visit My Home Page www.CREWZIN.com Last edited by CREWZIN; 03 Sep 2009 at 04:26 pm. |
A very big screwdriver/small crowbar?
With steady pressure on the piston, it should go in...
ive got a big enough g clamp now, just need to get my son to sleep so i can sort it. when bleeding brakes is it ' open bleed valve, press brake, close valve, lift brake, repeat?
I have found that when you depress the piston the fluid will just go back into the system. Unless you open the line to the atmosphere you shouldn't have to bleed them after.
![]() 2008 Silver Steel Metallic, Touring, NA, Sirius; Chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty Cover; Autolite AP5263 Platinum Plugs (.040); Crane Plug Wires; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot Rest Pedals, '05 Rear Step Pad, Stainless Door Sills, Llumar tint, "A" Piller chrome; APC Strut Bar |
Agreed. Just turn the C clamp slowly...
Wow i changed my rotors/discs & pads last night it was too dark to check the brake fluid level so i left it till this morning and everything works. i tried an emergency stop and the ABS kicked in just fine. I may still bleed the brakes but i dont think its necessary
| brake question | 4SPEED | General Turbo Discussions | 8 | 03 Jul 2009 06:07 pm |
| 2007 PT No Brake Lights Question | katfishgr | Tech & Performance Forum | 13 | 07 Jul 2008 02:56 pm |
| question about brake noises | 4SPEED | Tech & Performance Forum | 6 | 25 Jun 2008 05:41 pm |
| Turbo Brake System Question | R_I_PT | Turbo Wheels/Suspension/Handling | 5 | 03 Nov 2007 07:44 am |
| Brake pad replacement question | nozzano22 | Turbo Performance | 17 | 09 Dec 2004 02:42 am |
