Front Wheel Bearing/Hub Assembly Help
Old 25 Sep 2009, 05:15 pm
Default Front Wheel Bearing/Hub Assembly Help
Hello, I read a bunch of posts and it seems the wheel bearing problem is quite common, and I'm pretty sure mine has run into that one now.
I have 2006 with about 60k on it, just a normal one nothing fancy. When I'm driving down the road it makes a grinding noise and when I turn the wheel left it goes away but turning it right does nothing, so I know the problem is in the left bearing.
My question is, do I need to replace the whole hub assembly or just the bearing? Also, what tools/equipment do I need to complete this job? I've done a lot of engine work on cars but never did anything with the suspension so it's new territory for me, any help would be appreciated.
Thanks,
-Mike
Old 28 Sep 2009, 02:34 pm
Default Re: Front Wheel Bearing/Hub Assembly Help
You missed a post on just this subject in the tech section. Essentially, the bearing gets pressed onto the hub and into the hub mount after the old parts are pressed out. You need an arbor press and a bearing spreader to do it.
My gut feel is that you could save some money it you removed the hub and bearing assy and found a shop with a press.
knock sound in front pass wheel well, 01 pt cruiser sickened1 Wheels, Tires, Suspension 8 02 Oct 2009 02:56 pm
Something fell off the front right wheel area parker2004pt Tech & Performance Forum 3 31 Mar 2009 10:41 am
front wheel bearing debspt Tech & Performance Forum 1 01 Oct 2006 11:42 am
Eliminated Front Wheel Hop purplept Turbo Performance 2 02 Aug 2004 11:49 pm
Need help fixing a lug bolt. KurtPT Tech & Performance Forum 4 12 Aug 2003 06:03 pm
  Wordpress Theme | Jobs search | Nutritional Supplements | Debt Consolidation | Deaf Topics
