I have a very unique question on wheels
Old 24 Sep 2003, 11:53 pm
Default I have a very unique question on wheels
I am about to pick up my base pt cruiser, and I want to change my wheels the same day I buy it.
the wheels I want are 18", gunmetal, deep-dish(not too deep dish) and stick out about half an inch from under the fender for an aggressive look.
MY questions.
1. how do I get the wheels to stick out. Do I have to buy hubcentric spacers or can a get a wheel with a low offset, of say -10 to +10 to achieve the same look?
2. IS there any danger in using an offset other than +40. IN this case say +10?
3. If I have spacers or a low offset, can I go with wider than recommended tires on the back, like 255?
thanks a lot for helping me answer these. I searched high and low before finally deciding on a new pt cruiser and I am ecstatic about owning it.
Old 25 Sep 2003, 12:40 am
just buy a wheel with a wider rim then stock, try 8-10inchs wide.
Old 25 Sep 2003, 01:40 am
will a 10 inch wide wheel not have problems with the springs or something?
In Every situation, there is a fool. If you can\'t spot the fool,you are the fool.
When Peter talks about Paul, you learn far more about Peter than you ever do about Paul.
Old 25 Sep 2003, 11:01 am
dude goto a tire shop!
check tirerack.com
wider tires in the back of a front drive car, no good
Old 25 Sep 2003, 12:02 pm
You should probably contac
connor@tirerack.com
He can give you an accurate and informed answer
Old 29 Sep 2003, 03:24 am
I still dont have the info I need.
CAN SOMEONE HELP ME?
Connor recommends up to 235/40 in the front. THat does not help me at all. I dont even know the maximum wheel size that will fit without hassle on the cruiser. This is really frustrating me.
Connor also cant tell me what size width I can go up to if I add 1" spacers before the wheels. Is there a way I can calculate this?
I just want to know this: Can I fit 245/45/18 on all four corners without any rubbing or clearance problems? Thats my simple question and I still dont have an answer.
Other question is, how much wider can I go if I add the 1" spacer (25.4mm) Can I get up to 265?
I know a guy that has 265/30/19 on his pt cruiser but I cant contact him to ask if he had to have any mods done to the thing.
PLEASE HELP
Old 29 Sep 2003, 09:45 pm
drive the car to a tire shop that sells rims, try a few on, simple!
265/30/19 would be 10.4 inch's wide x3.12 sidewall hieght for a total diam. of 25.25"
235/35/19 would be 9.25 inch's wide x3.24 sidewall height for a total diam. of 25.48"
stock GT
205/50/17 would be 8.07 inch's wide x4.04 sidewall height for a total diam. of 25.07
since peeps lower their vehicls all the time, you won't have a problem with the hieght of the tire, now I will search for info on the spacing for you.
Old 29 Sep 2003, 10:40 pm
Punch,
I THANK YOU.
I really appreciate the time.
I have a question. Now that I know I wont have any clearance problems (since I will not be lowering the car)
can you tell me if a width of 245 will cause any problems with the springs. I would hate to go to a tire shop and have them fitting wheels all day.
Also, at the 8 inch wheel width, what offset wheel be necessary.?
Thanks again Punch
Old 29 Sep 2003, 10:58 pm
hi punch,
I figured out your calculations, and I figured that my choice of
245/45/18 will result in an overall diameter of 26.68
If I go down to 245/40/18, its 25.7, which does not quite fit the wheel well enough for my liking.
My question is, is the 26.6 overall diameter too much? I dont think so, but I need an educated opinion( I know it will mess up my speedo reading but I can live with that.
Old 30 Sep 2003, 01:32 am
The 245/45-18 will cause the speedometer to run 6.4% to slow. At an indicated 60, you will be doing 63.9 mph. That should not be enough to confuse the computer too much.
Do "KLEEN WHEELS" really work??? Gary04GT Wheels, Tires, Suspension 15 12 Oct 2008 07:44 pm
Question: Wheels and PT Wheel Wells PTGT_Boy Turbo Wheels/Suspension/Handling 42 13 Sep 2004 11:46 pm
Question about chrome wheels coolvirus The Detail Shop 2 08 Jun 2004 10:20 am
Question about the factory chrome wheels coolvirus Turbo Wheels/Suspension/Handling 2 30 Mar 2004 01:35 pm
General Wheels, Tires, and Rims Question... gravity Tech & Performance Forum 2 10 Oct 2002 06:17 pm
