Corroded rims causing air to leak.
  #11 (permalink)
Old 31 Oct 2009, 04:00 pm
Matt42's Avatar
Red face Now they're coming thru the door.
This thread is extremely educational for me. My 2001, new to us early this year, came with the dimpled polished aluminum wheels. They are showing no propensity to lose air, with the Michelin Pilot tires. (Hence my question, several posts above, about the Korean brands that ooze air in my experience.) The 2001 was purchased in SoCal, and then moved to Arizona in about 2004. Neither location was prone to corrosion.
I really like the dimpled wheels. I mean really like `em.
On the basis of the experience with the 2001, I began the process of acquiring them for my 2004 as this thread was developing. It's too late to back out of the deals, and I keeps my woid, yessir I do. I'll give the wheels a close inspection and report back, if there's anything to report.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, 2004 PT Cruiser Base 5 speed, 2007 Chrysler T&C Touring
  #12 (permalink)
Old 03 Nov 2009, 02:34 pm
Default Re: Corroded rims causing air to leak.
and again.....i had some luck with buffing the corrosion off with the tire off the rim.....been two monthe now....oh yeah i still need new wheels
  #13 (permalink)
Old 03 Nov 2009, 05:29 pm
Man i know this is so OLD school but is hey im gonna ask I know they make tubes for radial tires so my question is in place of replacing the wheels is it not possible to just tube the tire??????
I have a older Chevy 1 ton dully and it has radials on it and i have tubes in all 6 wheels I cant really see what problem it would cause--- just a question and a way cheaper answer that a full set of wheels
  #14 (permalink)
Old 03 Nov 2009, 08:20 pm
Matt42's Avatar
Duuuh. Old school, but it should work just fine. The key is to use tubes for radial tires. Regular tubes will cause more problems than just oozing air. The result is a Bad Thing.
  #15 (permalink)
Old 03 Nov 2009, 10:40 pm
link to said tubes?........
  #16 (permalink)
Old 04 Nov 2009, 07:02 pm
Matt42's Avatar
This is the sort of thing you find by going in to a full service tire store. Look for an employee old enough to remember carburetors and ask.
A Google search didn't return anything useful. This isn't a do it yourself project anyhow.
  #17 (permalink)
Old 04 Nov 2009, 10:41 pm
i dont suggest using tubes.
  #18 (permalink)
Old 05 Nov 2009, 11:09 am
odd things happen my S-10 has alloy rims I had tubes put in all 4 tires and that was 2 years ago important thing is to use radial tubes way cheaper than a new set of wheels
  #19 (permalink)
Old 07 Nov 2009, 03:58 pm
I too am having this problem. Tire went flat, not realizing, backed out of my parking spot, then discovered it. Had it towed and was told I had indeed caused some damage to the tire as well. I've had the air lead problems since I bought it new, 2001. I did have the wheel sanded and it lasted awhile, but came back pretty quickly it seemed. I also just failed my car inspection due to bad front right tie rod. I live paycheck to paycheck and no means of borrowing money or charging it to get it fixed. So, does it make sense for me to go to purchase a new tire and wheel myself and have the service station fix it or just let me order them? Also what is a resonable cost to have the tie rod fixed, plus i hear it will need to be balanced and alighned, is the alighnment imperative at this point? Being a woman on my own and broke, I want to try and not be overcharged or told I need more than I really due.
Sorry guys, you know us women, nothing is short and sweet, lol.
Brenda
  #20 (permalink)
Old 07 Nov 2009, 06:44 pm
Buy the tire at Sears, lifetime balance. If you buy all 4 there, lifetime rotation also. NOT trying to suggest you buy all four. Do you have road hazard on the ones you have now?
2008 Silver Steel Metallic, Touring, NA, Sirius; Chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty Cover; Autolite AP5263 Platinum Plugs (.040); Crane Plug Wires; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot Rest Pedals, '05 Rear Step Pad, Stainless Door Sills, Llumar tint, "A" Piller chrome
Subwoofers causing door and dash speaker distortion(?) StoneBullet Sound and Security Forum 16 01 Nov 2009 11:24 pm
Computer Causing PT Cruiser to Stall at Low RPMs/Turns??? pulpjava General PT Cruiser Discussions 7 26 Mar 2009 06:38 am
Impending turbo doom, or just a clogged oil return line causing whine and smoke? icezebra Turbo Performance 5 05 Oct 2008 04:14 am
vibration causing dash to rattle Easymover Tech & Performance Forum 3 26 Jan 2006 07:34 pm
First Oil Leak? Ack! beebs General PT Cruiser Discussions 4 18 Oct 2003 10:55 am
  Golf Jyouhou | Find jobs | MP3 Players | Debt Consolidation | Submit articles
