My front tire on my 2001 limited edition PT cruiser has a slow leak. I went to get it looked at and they told me, "Eventually you'll need to get new rims" and filled my tire up. They said that my valve stem hole was corroded and may eventually cut the valve stem.
So I did a lot of googling and found out that many other people have this same problem. I don't know what the next step is. Do I contact a Chrysler dealership? Buy new rims? Take it to a tire specialist and have them sand off the corrosion? I have to make a 200 mile drive tonight and am worried that my car is unsafe to drive on. What would you advise? |
You've already Googled and found out that many others have the same problem. Contacting Chrysler after the car has been on the street for 9 years will only result in laughter on the other end of the line.
The best thing to do is have the wheel taken apart and sand down the rusty parts (probably all around the whole rim). Coat those parts with some sort of rust inhibitor. That will probably hold your air leak to a bare minimum and then save up for new wheels. As far as your drive tonight, it's kinda late to do anything now. Check your spare tire to make sure it's filled up. Read your owners manual to find out how to change your tire if needed. Check to see if you have a tow/rescue policy with your insurance. Pick up a can of "Flat Fix" for an emergency, and lastly, keep checking the tire as you go along. Your better off with a few pounds over inflated than under.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. Original Owner, 110,000 miles MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a Garage. Visit My Home Page www.CREWZIN.com Last edited by CREWZIN; 23 Oct 2009 at 03:00 pm. |
I've had my car for 3 years and have taken it from 60,000 110,000 miles on it. This is frustrating me enough to get rid of it, but I suppose that wouldn't be the best idea. |
Most of your answers depend on where you drive. I've had my chrome (GT) wheels since 2003 (traded my 10 spoke custom 16" for someones 17" GT's) and they are perfect. But we don't see snow or salt on the roads down here in Florida.
If your in a state with salt in the winter and you don't like to clean and wash the wheels every time you take it out in that kind of weather, you should go for the painted wheels. If you clean off the wheels really well and coat them as I suggested, you should monitor how they are doing as far as loosing air. If it stops the leaking then you can keep them. If not, it depends on how bad the leak is/gets further down the road. If it needs air every other day, then look arond for replacements.
As far as I know nobody has been able to fix those poor quality wheels from leaking permanently. Get rid of them.
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, 2004 PT Cruiser Base 5 speed, 2007 Chrysler T&C Touring |
I have a 2004 PT Cruiser that came with chrome wheels. During the past year three of the four tires were always losing air. I brought it into the shop and they removed and sanded the rims - supposedly to remove corrosion - but this didn't help at all. It got to the point where I was having to put air in my tires every week.
I finally went out and bought new rims from tirerack.com. No air problems since, and I think the ones I bought look nicer than the original chrome ones.
Well known problem. Friend of mine here has to air up his tires every day. He's adamant that he's not going to buy new wheels. His have been leaking for three years, but he's an idiot anyway...lol... I'm wondering if this isn't why Chrysler switched to the steel rims that were chrome clad, like my factory wheels. They don't have the same problem. To really fix your problem you need to have the wheels go through abrasive blasting (sand blast) and then an acid bath and a revisit to the chromer. Not worth the cost, as they are a POS anyway. You'd do better buying new.
Yup. One of mine has been leaking for a pretty long time now. No visible damage on the outside of the rim and I've been told it's pretty corroded. The car started up in the northeast, so that's probably the culprit. I've done everything listed short of the blasting recommended in the previous post, but to no avail. The only cheap solution: a cheap air pump with a 12v cigarette lighter cord and a tire pressure gauge in the car with me at all times.
![]() Luckily, my new rims should be here in about a week.
2001 PT Turbo - In the process of a major overhaul.. :] 2006 Cobalt SS/SC - Stage 2, 3" Exhaust, Meth and soon to come: Zex 75-shot :]
| Subwoofers causing door and dash speaker distortion(?) | StoneBullet | Sound and Security Forum | 18 | 29 Nov 2009 06:16 pm |
| Computer Causing PT Cruiser to Stall at Low RPMs/Turns??? | pulpjava | General PT Cruiser Discussions | 7 | 26 Mar 2009 06:38 am |
| Impending turbo doom, or just a clogged oil return line causing whine and smoke? | icezebra | Turbo Performance | 5 | 05 Oct 2008 04:14 am |
| vibration causing dash to rattle | Easymover | Tech & Performance Forum | 3 | 26 Jan 2006 07:34 pm |
| First Oil Leak? Ack! | beebs | General PT Cruiser Discussions | 4 | 18 Oct 2003 10:55 am |
