Suspension bottoms out.
Old 25 Oct 2009, 12:57 pm
Default Suspension bottoms out.
2001 PT Cruiser rear bottoms out easily in small bumps.
Can anything be done to smooth out the suspension?
Old 25 Oct 2009, 03:55 pm
Default Re: Suspension bottoms out.
If it bottoms out real easy, either your shocks/struts or springs are shot. If you lowered it yourself with lowering springs, then you forgot to cut the bump stops.
You can cut the bump stops even if you didn't lower it yourself to stop it hitting on bumps but your bypassing the point of my first statement.
Old 25 Oct 2009, 04:05 pm
Hi CREWZIN:
The car hasn't been lowered and the shocks show no leaks. I have 77,000 miles.
Maybe I should replace the rear ones to see if it makes diference.
Do you recommend any particular ones?
Thanks
Old 25 Oct 2009, 04:12 pm
I chnaged both front struts and back shocks with TOKICO. But the write-up says they are made for lowered cars. I also have the Eibach lowering kit.
Looking for suspension... HeavyMetalFL Wheels, Tires, Suspension 14 17 Jan 2011 03:48 pm
Suspension kit bluekisses07 Wheels, Tires, Suspension 0 28 May 2008 10:35 am
KW Suspension Rolo Wheels, Tires, Suspension 18 16 Jan 2004 10:00 pm
KW suspension lip Turbo Wheels/Suspension/Handling 19 24 Nov 2003 06:37 pm
Air suspension Ed Lim Wheels, Tires, Suspension 1 10 Sep 2003 05:13 pm
