Okay, I've got a 2001 PT with a bad front wheel bearing... Not too bad at 140,000 miles to have to replace a wheel bearing... Anyways, seems there was a design change to the wheel hub between 2001 and 2002 on these, according to this article:
"The Timken Company (Canton, Ohio) announced it will be supplying DaimlerChrysler's Chrysler Group (Auburn Hills, Michigan) with more bearings in 2002 for the hot-selling Chrysler PT Cruiser.
Most significantly, the 2002 PT Cruiser will be using Timken's UNIPAC ™ front hub assemblies with tapered roller bearings.
The PT Cruiser currently (2001) uses NSK hub assemblies with angular contact ball bearings.
For the new front hub assembly, Chrysler called in four bearing manufacturers and asked for designs which would have quadruple the service life of the current unit. Three presented larger ball bearing units, while Timken's not only used tapered roller bearings but also had the same dimensions as the current unit.
Chrysler's switch from ball bearing to tapered roller bearing hub units in the same vehicle is not unprecedented. A number of years ago, General Motors found ball bearing hub units in its larger front-drive cars were not holding up. A new tapered roller bearing hub assembly was developed with the same envelope dimensions and installed as a running change. "
Okay, so now here's my problem.... Because I know I should replace the hub along with the bearing.... I found that the hub for the 2001 is not available aftermarket, and I have to pay a small fortune at the dealer for the part.
My question is, with the info from the article about the 2002 Timken design being "same dimensions as the current unit" and "installed as a running change" I'm hoping that possibly the 2002 hub and bearing can be installed on the 2001 PT.
Has anyone tried this? Any issues? If at all possible, due to the greatly reduced cost and aftermarket availability, I'd like to install the 2002 hub and bearing on my 2001 PT. I found 1 internet parts site that says the same hub fits 2001-2009 (most sites only list 2002-2009), so I'm hoping perhaps this is a perhaps little known replacement option, and not just a mistake on the part of the parts site. From the look of the part, at first glance it seems like it should do the job, since I don't think the axle shaft has changed between model years.
Any guidance would be greatly appreciated.
