My front end sqeaks when I go over bumps
Old 02 Dec 2009, 11:51 am
Question My front end sqeaks when I go over bumps
Hey, I just put new winter tires on my 2004 pt Cruiser (basic) about a 5 days ago, and yesterday my tires started to make a squeaking noise when I go over a bump, it sounds like shocks or something rubbing, I guess it sounds more like a creak then a squeak. Any ideas?
Old 02 Dec 2009, 05:57 pm
Default Re: My front end sqeaks when I go over bumps
Very likely it's rubber bushings.
If you are agile, drive car up on ramps and spray every suspension jucntion with rubber with either silicone spray or WD-40.
A more permanent cure is to find a mechanic who will replace the bushings - a dealer will swap out parts that have the new bushings in them to cut down on labor.
Old 02 Dec 2009, 07:23 pm
Check the endlinks on the front sway bar. Ours went bad on my wife's '04 and the car sounded like it was 100 yrs old with all of the creaking going on.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Tags
creak, tires
02 to 06 front end fordeater Exterior Accessories Forum 2 14 Aug 2009 03:27 am
Front ceramic front brake pads coopj40 General Turbo Discussions 1 17 Mar 2007 06:42 pm
2001 Metallic clunking in rear on bumps harleysforfun Wheels, Tires, Suspension 5 16 Jan 2007 11:24 am
Harder bumps after changing from 205/50 to 225/45? Jeff V Wheels, Tires, Suspension 8 15 Apr 2005 10:53 am
idle bumps VellianPT General PT Cruiser Discussions 3 23 Nov 2004 10:37 am
