Front Hub/Bearing Replacement
Old 04 Dec 2009, 12:38 pm
Default Front Hub/Bearing Replacement
I've got to replace the front bearing on the left side of the car.
I found a bearing assembly and then at Autozone.com I found a hub with bearings, but I'm not sure if it's assembled or not.
Can the front hub be removed from the car without having to break the entire front suspension down? It's cold where I live and I've never taken the control arms or struts out of a front wheel drive car before. if I don't need to, that would be a huge bonus.
Thanks,
Scott
Poll: Wheel Bearing Replacement 2004PTGT Wheels, Tires, Suspension 141 16 Feb 2011 09:41 pm
New PT owner needs help with front brakes and maybe bearing replacement. Frankvs73 Wheels, Tires, Suspension 2 27 Oct 2009 07:15 pm
Detailed instructions for CV axle and hub bearing replacement? Samson Tech & Performance Forum 1 27 May 2009 12:32 pm
How do you get the front bearing out of the HUB??? llcelebrity Tech & Performance Forum 5 10 Feb 2009 04:04 pm
CV shaft after hub and bearing replacement? 2004PTGT Wheels, Tires, Suspension 9 17 Jul 2008 06:51 pm
