Control arm bushing
Old 08 Dec 2009, 09:58 pm
Default Control arm bushing
In trying to replace the control arm bushing the top nut appears to be spinning in the frame. How can I remove the bolt so that I can replace the bushing? Is there a way to hold the nut inside the car?
Old 22 Feb 2010, 12:28 pm
Default Re: Control arm bushing
Too late timcathy you are in for the worst nightmare of your life now There is no way to hold the nut from inside the car because there is no nut on top of that bolt.
There is an oval piece of mild steel with 2 flat sides that is designed to spin when you try and undo it. I say it was designed to do this as no person in their right mind would have created this other wise without first undergoing a frontal lobotomy.
Around this squared of oval piece of mild steel is a kind of cage built from the inner skin of the sub frame which is supposed to stop this so called nut from turning when undoing the bolt. Unfortunately it is soft as shit and just expands and allows the excuse for a nut to spin.
The only option you have open to you now is cut a hole in the sub frame next to the bolt and get someone to weld the so called nut to the sub frame hopefully it will hold allowing the bolt to be removed. then replace bushes and put the bolt back in and then get a plate welded over the hole you have had to cut. I can provide some pictures if you like just so you get a feel for the nightmare you have unwittingly entered.
good luck
Old 13 Mar 2010, 03:33 pm
IMIEIW's Avatar
Send a message via AIM to IMIEIW
Does anyone know where I can find a diagram of the bushings and any suggestions with what to replace them with. Thanks.
Old 13 Mar 2010, 09:39 pm
Well I would replace the bush with another bush if I were you you could try a tree if you like but it would not fit.
If you want to see what one looks like just google front control arm bush. or go to your dealer and they will show you one. Its just a round tube of metal filled with rubber and another tube inside the rubber about 2 inches across and 4 inches long.
here is a link to a pic
http://www.autopartswarehouse.com/sk...n+%26+Steering
Lower control arm bushing TCH Wheels, Tires, Suspension 2 13 Jan 2008 01:00 pm
Bushing Kits? umaxman Canada PT Forum 4 24 Aug 2006 04:42 pm
Front Control Arm Bushing Question JohnM Wheels, Tires, Suspension 6 26 Aug 2005 11:40 am
pics of lower control arm bushing? crash2000 Turbo Performance 2 07 Nov 2004 10:09 am
Control Arm Bushing PTZCrazy Wheels, Tires, Suspension 6 08 Jun 2004 02:42 pm
