All those with front wheel bearing failure
Old 28 Mar 2010, 02:19 pm
Default All those with front wheel bearing failure
Someone on another thread asked about the ground strap that goes from the body to the front strut (one on each side). I said I remember reading somewhere that it had something to do with the front wheel bearings, although it sounded strange. I did some more checking and found this on PTCRUIZER.com
Make sure that your front strut ground straps are intact as these commonly rot off and can cause repeat failures. The factory was seeing some early bearing failures even though the lube in the bearing was still good. On close examination you could see pitting, actual arc marks, on the balls and races making them noisy. The current from road static charges and possibly poor engine to body grounds was passing through the bearing itself, greatly reducing its life. By adding ground straps and keeping everything at the same voltage potential solved the problem.
You can see the strap in the picture below of my front wheel well. Make sure you straps are intact.
Front Wheel Bearing/Hub Assembly Help UniSaitek Wheels, Tires, Suspension 1 28 Sep 2009 02:34 pm
Front Wheel Bearing?? mjb457 Tech & Performance Forum 3 12 Mar 2009 03:37 pm
front wheel bearing maintenance 4SPEED Tech & Performance Forum 1 29 Oct 2008 05:03 pm
Front Hub & Wheel bearing JoeHundredAire Wheels, Tires, Suspension 2 15 Jun 2008 11:25 am
front wheel bearing debspt Tech & Performance Forum 1 01 Oct 2006 11:42 am
