Bellcrank - rear axle
Old 01 Apr 2010, 07:24 pm
Default Bellcrank - rear axle
I have a 2001 Cruiser. The bellcrank on the rear axle is loose (this can be moved by hand with all four tires on the ground). This has been a source of a rattle coming from the rear for some time now. Is there supposed to be rubber or bushing material between the bellcrank and the mounting post on the axle or does this just need tightening?
Old 06 Apr 2010, 07:08 pm
Default Re: Bellcrank - rear axle
i am sorry i can not help you
but i have the same problem and the same year.
i need to change this part
but first i want to know what is the name exactly of this part.
Pierre-luc
Old 06 Apr 2010, 07:20 pm
xwing777's Avatar
Replacing Rear Watts Link Bushings
Old 07 Apr 2010, 07:43 am
XWING777 is right, I just replaced this using a dealer part. The bell crank only, not the linkages. Thos bushings were ok. It's not hard to replace, I found it easier to raise the rear on ramps to allow slak in the watts linkage for easier maneuvering. The watts linkages are pressed into the bellcrank, same as a tie rod end so a tie rod removing tool makes this easy.
I plan to take the old one apart to find out "what's inside".
Old 07 Apr 2010, 08:15 am
What does rattle sound like? I have one I can't find - from rear, sounds like light-gauge metal titting - like if license plate was flapping....
Any other symptoms? Car handle well?
Old 07 Apr 2010, 08:26 am
quicksilverdon, This noise was a heavy metal clanking noise with any rear suspension movement. This was only discovered while the car was on the ground - no jacks or raised at all. When the car was raised by the body the bellcrank "slop" was tightened up and would not move.
For yours, check the fuel fill line and spare tire set up. Or quite possibly something stashed (toools, coke cans, etc) in one of the side rear comparments (made that mistake once).
Old 14 Apr 2010, 09:17 pm
twress's Avatar
I also changesd out my watts-link on my new Woody today. It took under 2hours. I also had a loud clunk when I hit a bump. You can tell by looking at the center of the rear axle where its located. Have someone push the PT side to side you can see if the Watts link wobbble and clunk if its bad.
ROUNDIN UP THE WAGONS 02 LIMITED WOODY, 89 CAPRICE CLASSIC
Old 16 Apr 2010, 10:09 am
twress's Avatar
I posted Watts link or Bellcrank removal and how to do it on a thread. There is no rubber bushing between the bellcrank and mounting post. The long bolt goes through the watts link through the shaft with no bushing and attaches with a nut and washer.
Old 02 Jul 2010, 06:14 am
i have a rattle when i drive changed the shocks and still there when. If i shake the pt left to right it dosent rattle or clunck about any other ideas as what it can be but it does sound like its coming from middle of the car
Old 05 Jul 2010, 03:31 am
There are many producs in the market ,but according to the use frequency,this product is the best choice, I bet you will have a suprising result,just have a try!
ipod computer
download youtube
10K, 1 Year, & Needs New Axle??!! jlwn111 General PT Cruiser Discussions 28 27 Jun 2010 07:26 pm
Which axle back exhaust? nozzano22 Turbo Performance 1 11 Jul 2004 10:57 am
..rear axle adjustment? earringboy Turbo Wheels/Suspension/Handling 2 03 Jan 2004 07:59 pm
BTG axle back exhaust GTSteve General Turbo Discussions 24 08 Oct 2003 12:38 am
BTG axle back muffler GTSteve Tech & Performance Forum 1 21 Sep 2003 01:02 am
