Rotors
Old 02 Apr 2010, 04:03 pm
Angry Rotors
I was told it was easy to replace my rotors on my 2006 non turbo pt cruiser, and that you do not have to remove the center wheel bearing nut. Well I have tried for an hour using a rubber mallet and still I can not get this rotor to slide off, are you sure to not have to remove this nut.
Old 02 Apr 2010, 04:14 pm
Default Re: Rotors
The center wheel bearing doesn't have to come off. Are you sure there isn't a small screw around the center of the rotor holding it on? If not, it's probably rusted on really tight. The caliper is completely off, right? Look at the new rotor and you should be able to tell that it just slides off and on without touching the center bearing.
Unless of course Chrysler did something different on the 2006+ cruiser that I don't know about.
Old 02 Apr 2010, 05:49 pm
Smile Re: Rotors
Thanks for your quick responce I got the rotors off eventually they were just rusted on,I had already removed the clips on the wheel studs previously and I think these were the original rotors 40000 miles, thanks again.
Old 02 Apr 2010, 05:52 pm
Default Re: Rotors
Your welcome, glad you got it off.
Old 05 Apr 2010, 11:19 am
Default Re: Rotors
A lot of shops will heat them up with at torch to break the rust.
GT Rotors mljorg Classifieds: For Sale/Trade 5 13 Feb 2009 12:44 am
Rotors RossCoe Turbo Wheels/Suspension/Handling 10 21 Jun 2006 11:47 pm
Rotors??? 1lowufo Tech & Performance Forum 5 23 Jan 2006 05:24 pm
powerslot rotors for gt gooberff General Turbo Discussions 6 24 Nov 2005 12:52 pm
