Shock gas ajust orGR2 help
Old 04 Apr 2010, 03:59 pm
demon666's Avatar
Default Shock gas ajust orGR2 help
Hey guys me again.
MY coworker said he has some extra shocks there KYB SHOCK ABSORBER the one thing I dont know is they say there Gas a Just
then i seen some other ones that say GR2 / Execel G" dont have a clue .
And is this brand ok to install ?
Old 04 Apr 2010, 04:09 pm
Default Re: Shock gas ajust orGR2 help
KYB are good shocks. What do you mean by "he has extra"? Were they for a PT Cruiser? You can't just put any shocks on your car. Does he have the KYB struts also?
The GR2 / Excel G are other names of KYB. Read here:
KYB America LLC Shocks & Struts | Technical Information | FAQ 06
Old 04 Apr 2010, 04:19 pm
demon666's Avatar
Sorry should have been more clear he bought them for his 2005 pt cruiser never got to install them be for he sold it. we looked them up and they to fit on my 2004 trying to figure out if i can save some money or i should buy a beter bran?
Old 04 Apr 2010, 04:28 pm
If you believe you need new shocks and struts, they are a good brand to have. Normally shocks and struts last quite awhile 50, 60 70,000 miles plus.
Old 04 Apr 2010, 04:45 pm
demon666's Avatar
My 2004 PTC just hit 60300 miles they have all the original shocks I would feel much better having new ones on.
Am also thinking of changing the control
arms the ball joints are also not looking to good cracked and i think its far easy and less tools need to change the ball joints so am told .
Old 04 Apr 2010, 05:36 pm
Don't know. I have 102,000 miles and everything in the suspension is original except the lowering springs and the Tokico Struts and shocks which were made for lowed vehicles.
Old 05 Apr 2010, 06:22 pm
demon666's Avatar
The link did not say what is a better shock ,
what am trying to find out is should i install a KYB GR-2 SHOCK ABSORBER, or a KYB GAS-A-JUST SHOCK ABSORBER I see the gas a just will cost about 20.00 more are they better ?
Old 05 Apr 2010, 06:34 pm
Unless you come across someone that knows or had tried both kinds of shocks and struts, your going to have to make up your own mind. Read up all you can and make an informed decision.
KYB GR-2 / EXCEL-G Gas Shocks & Struts
KYB GR-2 / EXCEL- G Shocks Restores a vehicle’s originally designed handling and control
* Calibrated to compensate for worn suspensions
* Components and valving are designed specifically for each application
* The best choice to restore OE performance and normal driving conditions
* Built with quality that matches or exceeds OE
* Coverage for domestic and import cars, trucks, vans, minivans, and SUVs
* Click here to perform a search for your car KYB Gas Shocks & Struts
KYB Gas-A-Just Shocks
KYB Gas-a-Just Shocks are designed to deliver the maximum driving control & performance. Gas-A-Just's higher gas pressure keeps tires glued to the road while its high strength, monotube configuration provides extra-rugged durability and fade free performance.
KYB Gas-A-Just Shocks Significantly increases vehicle stability, handling, and control over twin-tube designs.
* Gas-a-Just is the replacement for an OE monotube shock
* Ideal as an upgrade from an OE twin-tube
* The more responsive monotube design automatically adjusts to driving conditions
* Applications for cars, trucks, vans, and SUVs
Old 05 Apr 2010, 06:42 pm
demon666's Avatar
thanks that was more then what i found.
SHOCK ABSORBER RECOMMENDATION clevelandmike Tech & Performance Forum 5 09 Nov 2004 05:08 pm
BTG shock strut bar mcruz Turbo Wheels/Suspension/Handling 2 13 May 2004 10:09 pm
Koni Shock ? OurPTGT Turbo Wheels/Suspension/Handling 10 16 Aug 2003 02:31 pm
Shock upgrade OurPTGT Turbo Wheels/Suspension/Handling 22 17 May 2003 05:17 pm
Shock Tower Strut American flyer Tech & Performance Forum 17 14 Dec 2002 10:20 pm
