Watts-Link or Bellcrank Replacement
Like Tree16Likes
  #91 (permalink)
Old 12 Mar 2016, 02:34 pm
Default Re: Watts-Link or Bellcrank Replacement
the tie rod ends on the link bars appear to be crimped on...I just bought the watts link and both bars from Rock Auto....ordered parts....parts arrived 2 days later and it was $78 with shipping
  #92 (permalink)
Old 13 Mar 2016, 07:07 pm
Flowrider's Avatar
I did this 2 weeks ago and it is much easier to remove the entire watts link and both tie rod arms that connect to it as 1 unit. Installation as a new 3 piece unit with all new watts link and both tie rod arms was very quick. I also used a cordless impact wrench to speed things up.
myckee likes this.
Say No To Stock! Cruisers should be customized!
  #93 (permalink)
Old 26 Jul 2017, 10:10 am
Great write up. I replaced the Watts link a couple of days ago. It wasn't too difficult.
- replace Watts link only
- supported the rear axle on jack stands. This allows you to put a ratchet on the bottom bolt once the center bolt is out.
- the nut on the center bolt was 21mm (odd!)
- had to use a impact on the bottom bolt
Thanks everyone. Your experiences made this job pretty easy.
Replacing Rear Watts Link Bushings ddakin Turbo Wheels/Suspension/Handling 3 28 May 2012 01:08 pm
Front end link bushing replacement? Samson Wheels, Tires, Suspension 21 26 Jul 2011 10:14 pm
Bellcrank - rear axle argos587 Wheels, Tires, Suspension 11 07 Jul 2010 07:27 am
Were to buy Watts Center Bushing rspiegel Wheels, Tires, Suspension 1 30 Nov 2009 03:21 am
watts link part numbers visual1 General PT Cruiser Discussions 4 21 Aug 2009 02:12 pm
