Thumping noise/feeling on floor board??
Old 10 May 2010, 02:55 pm
Default Thumping noise/feeling on floor board??
I have a 2001 PT limited with 139K miles on it. I just replaced both of the front bearings, new break pads, and had the rotors turned less than 4K miles ago.
** Side note - thanks to all the posting here, because it walked me through the entire process without any problems.
Everything has been fine since then, but now anytime I get to 70mph or faster - I start to feel a thumping in the floor board. I'm thinking it may be the drive axles but wanted to see if anyone else had seen this issue or might point me in a different direction.
Thanks
Old 10 May 2010, 03:34 pm
Default Re: Thumping noise/feeling on floor board??
I don't think the drive axles would thump on the floor (I could be wrong). I'd get it up on a rack and check the whole exhaust system especially the loop that goes over the rear axle. It could be hitting there.
Old 11 May 2010, 06:12 am
I'm sure the thumping I feel is not in the back of the car. I can feel it on my feet and tell it is coming from the front of the car, like it has something to do with rotation. Like the feeling you get when a tire is out of balance and has a hop to it.
Old 11 May 2010, 07:17 am
Welcome.
You tighten up the bearings properly?
Did you have tires checked?
Drive it up on ramps and look at all suspension links - check the bushings.
Old 01 Nov 2011, 06:30 pm
Did anyone determine the solution on this one?
I have the exact same thumping noise though only around 25mph & 45-50 mph... ive looked around the suspension and cant seem to find anything wrong (at least thats obvious...)
Thx.
2001 LE, 119k...prob all orig susp bushings...
Cheers!,
-John
2001 Limited Edition
Old 02 Nov 2011, 03:56 pm
Exclamation Re: Thumping noise/feeling on floor board??
and a vid to show how excellent the thumping sound is.
What's odd is that it can vary when it actually happens based on the surface, which leads me to believe it's likely a bushing issue, but also could be some kind of end-link or ball joint...
Tub-Thumping - YouTube
Cheers!,
-John
Old 02 Nov 2011, 05:08 pm
Send a message via AIM to slayerdarkcross Send a message via MSN to slayerdarkcross
Wow sounds exactly like a helicopter in the video haha>
I dont have much to say on resolving it though
Old 02 Nov 2011, 05:18 pm
LOL- i thought the exact same thing ( my pops flew Hueys in the Army-unforgetable sound). Will post up what the issue actually is/was if i ever get time to work on it.
Cheers!,
-John
Old 07 Nov 2011, 06:31 pm
Talking Re: Thumping noise/feeling on floor board??
Decided to play with my webcam, netbook, and some duct tape.
No diagnosis yet, but if I can get some time to play I think I can figure it out. It's just GOTTA be one of those darn bushings...LOL.
PT Cruiser Driver Side Control Arm Madness - YouTube
Edit: and this is on a pretty smooth, newly paved road.
Cheers!,
-John
Old 27 Nov 2011, 09:29 am
mine was doing this also @153k. i just replaced the LCA bushings with poly's last night. Haven't driven it yet but i feel confident this was the source of my clunking. I'll updated after my drive to Dunkin's this morning
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Tags
front end noise
new to the board slammed General PT Cruiser Discussions 4 06 Feb 2010 07:06 am
Lever on back seat toward floor board snazzysue Interior Accessories Forum 4 03 May 2009 05:48 pm
clutch thumping noise warpedhead General Turbo Discussions 2 23 Apr 2007 02:28 pm
I'm sure you know the feeling... ijoe General PT Cruiser Discussions 9 31 Aug 2004 02:24 pm
Its a great feeling... jmack General PT Cruiser Discussions 15 07 Jul 2004 08:37 am
