Front End Clicking and Power Steering Whine
Old 18 May 2010, 04:29 pm
Default Front End Clicking and Power Steering Whine
My Power Steering Whines each morning when I am driving around/up the parking structure at work. Only in the Morning and when it is cold outside. Is there anything I can do, or is this just an annoyance until something breaks.
Also, I get a, click type sound from the front end when going over a bump or a sharp turn into my driveway, like something is loose in the front end. I have checked several suspension bolts but nothing abnormal. I have replaced all the rubber a-arm bushings with poly bushings a year ago, so its not that. Any Ideas on what to look for?
Old 19 May 2010, 07:29 am
Default Re: Front End Clicking and Power Steering Whine
My PS "groans" when cold - I regard that as usual. If your noise is a "squeal", the belt may need replacing.
As for the click - check your brake pads - to tes, tap the brakes when you would usually get the noise and see if you still get the noise......
Old 19 May 2010, 05:52 pm
Thank You
Clicking and humming sound from front end? Samson Wheels, Tires, Suspension 5 06 Aug 2009 08:34 am
little clicking noise from front right wheel yaris General PT Cruiser Discussions 4 31 May 2009 09:45 am
Power steering whine problem identified sawdust123 General Turbo Discussions 5 10 Dec 2008 07:24 pm
Clicking in steering wheel deadant Tech & Performance Forum 2 25 May 2007 01:11 pm
Front Driver seat clicking Art Rigby Tech & Performance Forum 3 23 Jun 2004 02:23 pm
