Groan/creaking sound when turning wheel right (front right wheel)
Old 31 May 2010, 09:34 pm
Question Groan/creaking sound when turning wheel right (front right wheel)
Howdy Folks -
I'm hearing a groan/creaking sound coming from around the front right wheel when turning right at a slow speed (i.e.: coming to and/or leaving a stop sign with the intention of turning right). This also happened a few times while parked with the car on. When I hear this sound I can sometimes reproduce it by turning the steering wheel slightly left/right at the sweet spot at which it occurs.
[EDIT] Oh, to add some context *if* it helps any. I just came back from a weekend drive with a ton of curves, switchbacks, steep hills, etc. CA Highway 1. This sound started on the trip back home.
Any ideas? Thoughts or suggestions?
2002 pt / 69,200 miles
Thanks!
2k2tpc
Old 01 Jun 2010, 08:59 am
Default Re: Groan/creaking sound when turning wheel right (front right wheel)
Welcome to the forum.
My bet is a bushing.
Get under the car with a can of silicone spray and spray the bushings and see if noise goes away - then you have choice of living with the noise or having bushings replaced.
Old 02 Jun 2010, 12:17 am
Thanks quicksilverdon. Glad to be here : ) I'm going to give your guess a whirl. Will keep you updated.
Old 07 Jun 2010, 12:07 pm
UK_Cruiser_06's Avatar
Hi,
I've got almost exactly the same problem.
Mine started a while ago with a noise that would only occur on say 10% of times I pulled away quickly while turning right. Then the other weekend, I took it for a fairly quick drive along some twisty roads and noticed I started to get a creak/goran noise from the front right, accompanied by a slight vibration through the steering wheel when I was going round the right hand curves.
After having a good look round, I found one of the wishbone bushes (on the left) wasn't where it should be...
This is the one on the right (which looks kinda ok)
This is the one on the left:
Gave them a soaking with silicon spray for now and after its soaked in for a couple of days, the creaking seems to have quietened down a little.
Should be getting poly bushes put on next weekend for the wishbones and front anti-roll bar.
Hopefully that will sort the problem out and the poly bushes will last a bit longer (car is under 4 years old with 20,000 miles).
2006 PT Cruiser Limited
Old 07 Jun 2010, 03:33 pm
A couple of us are on the UK PT Cruiser site and the "bushes" as it's called over there is one of the biggest complaints as far as having to replace in a few short years. Maybe it's your damp weather.
Old 07 Jun 2010, 04:44 pm
Quite possibly - along with the state of our roads
I think the PT must have been designed with straight, smooth roads in mind, not twisty, crater ridden ones.
Oh well, small price to pay for having a cool and different car.
Actually, "small" is probably not the right word by the time you take into account our 'road tax' of between 215 and 425 ($315 and $620) a year and our $6.40 gallon...
Old 01 Sep 2012, 09:12 pm
oldorange's Avatar
My 03 pt has this if I slightly turn the wheel either way. Sitting or driving. Also going over bumps. Groans and creaks and squeaks. Does the silicone spray work? What about spray lithium grease? Can either be bought at the auto store? Thanks.
My 2003 PTOS... ...Will it ever STOP Squeaking & Creaking???!!! And 21 MPG, what's up with that?
Old 02 Sep 2012, 10:51 am
Control arm bushing.
Or strut mount :-)
Old 02 Sep 2012, 10:52 am
I have to replace mine every $25k whether i want to or not :-D
Tags
creak, front end noise, groan, sound, turn wheel
Does This Sound Like Wheel Bearing Problem?? NewPTCruiserInPA Wheels, Tires, Suspension 7 07 Apr 2010 07:26 am
knock sound in front pass wheel well, 01 pt cruiser sickened1 Wheels, Tires, Suspension 8 02 Oct 2009 02:56 pm
Creaking noise when turning wheel kappa_kruiser Wheels, Tires, Suspension 3 22 Jul 2008 06:14 am
clunking sound from front right end when turning any TSB mino General PT Cruiser Discussions 5 18 Oct 2007 03:04 pm
Slight whining while turning the steering wheel alceryes General PT Cruiser Discussions 4 02 Apr 2004 10:19 pm
