KYB Shocks, rear suspension
Old 03 Jun 2010, 07:44 am
Default KYB Shocks, rear suspension
I just finished installing KYB rear shocks on my 01 Cruiser. I was told by several different tire shops that my shocks were due to be replaced due to the cupping on my rear tires. I am not sure it was the right move or perhaps I just picked the wrong shock, because these KYB's seem much softer than the shocks that were on the car (not stock, but i can't identify a brand).
When performing the bounce test, the previous shocks basically had about one bounce before settling in, whereas these KYB's bounce at least twice. I am not sure if that is best way to measure anything, but I also noticed on the highway it seemed a bit bouncier. This seems to defeat the whole purpose of new shocks as I thought the problem with the cupping was caused by the rear end bouncing excessively and the shocks losing their dampening ability.
I am wondering if the rear tire issue was really caused by other rear suspension components being bad. I know the bell crank needs to be replaced. Any ideas?
Old 09 Jun 2010, 10:24 am
Default Re: KYB Shocks, rear suspension
The bad bell crank will allow the whole rear suspension to shift side to side which IMO would be the culprit with the cupping tires. I replaced the bell crank as well as the lateral links on mine and it made a huge difference in ride and handling.
Old 09 Jun 2010, 11:25 am
VNT's Avatar
VNT VNT is offline
I removed the watts pivot and trashed one of the lateral links. I have 2 new ones on order.
The center pivot(goes to the pivot point on the trailing arm) on the watts linkage was worn, slop in the center bushing.
Per the lateral links, the tie rod part on the two I removed seem awful sloppy and since I couldnt unthread the nut off one, I ordered 2 new repalcements. I guess I will find out how much play their is on the ends.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 24 Jun 2010, 08:59 am
Just finished driving the car several thousand miles on vacation, while the suspension still seems a little softer than I prefer, it doesn't feel as bad as I initially thought. Perhaps I am just getting used to it.
I also checked the Watts linkage and bell crank, and even though the boot is torn on the bell crank, everything feels pretty tight. I know at one point in the past when I had checked it, there was a lot of slop on it. I am thinking perhaps a mechanic tightened up the bolt on the bell crank during one of its trips to the tire shop and just failed to mention it to me, or maybe there is another reason. The watts linkage/bell crank, certainly seem tight enough to me at this point, but perhaps they move more under load.
FS: New Rear KYB Gas Shocks. 1BadPT07 Classifieds: For Sale/Trade 10 17 Feb 2008 02:09 pm
Rear springs and shocks only? Kenzenfighter Wheels, Tires, Suspension 2 27 Apr 2007 12:48 pm
Rear shocks only ok??? turbomangt Turbo Wheels/Suspension/Handling 3 28 Nov 2005 12:09 pm
Rear Hatch shocks/ toast??? turbomangt General PT Cruiser Discussions 3 09 Aug 2005 04:03 pm
Rear shocks DREAM2 Turbo Wheels/Suspension/Handling 19 23 May 2004 11:46 pm
