15" tire pressure?
Old 08 Nov 2003, 06:13 pm
Default 15" tire pressure?
I just installed a set of 15" steelies with snow tires on my GT Turbo. Would like to know what the manufacturer's reccomended pressure is for the 195/65-15 tires for those of you with factory 15" wheels.
Thanks
Old 08 Nov 2003, 07:04 pm
Your recommeded tire pressure should be on a label on the drivers door. Also check your owners manual for the topic 'Snow Tires', I believe it says to adjust your tires 4 psi higher when driving on snow. There's also information for the use of tire chains.
2002 Inferno Red PT Limited
Mercedes Wiki
Old 08 Nov 2003, 09:37 pm
Thanks, but the reason i asked is because the label on mine is for the 17" GT tires (38 psi), which I'm sure is too high for the 15" snows I just put on.
2003 GT Turbo, 5-speed, Deep Cranberry with factory flames
Old 08 Nov 2003, 09:48 pm
34 lbs is the normal pressure for the 16" tire, running 16" tires in the snow it would be 38 lbs, not sure if the 15" would be the same, sorry I couldn't help.
Mercedes Wiki
Old 10 Nov 2003, 07:05 am
My 02 Classic came with 15s, the label recommends 34 libs.
2004 Touring Factory Two-Tone
Nothing could be finer than cruisin' the Carolinas!
http://www.carolinaptcruisers.com
Old 10 Nov 2003, 03:03 pm
Thank You![8D] I had guessed 35...
Old 03 Dec 2003, 11:22 am
Hi!
My Chrysler-dealer recommends 40 lbs on the 16'' - so my PT Cruiser runs more more economical (gaz-prices in Germany are intolerable).
@IRPT: I know this label on the drivers door, but I take a little bit more.
Peter [8)]
Tire Accu-Pressure Safetly Cap Warning Curruzr General PT Cruiser Discussions 6 22 Aug 2005 07:46 am
Silencer and tire pressure purple04 General PT Cruiser Discussions 2 22 Mar 2005 01:12 am
Tire pressure recommendations OurPTGT General Turbo Discussions 11 14 Oct 2004 09:22 pm
Tire pressure lip General Turbo Discussions 2 10 Aug 2003 06:38 pm
