Questions about springs
Old 16 Aug 2010, 01:39 pm
Default Questions about springs
I have my 05 pt/gt. Ive been looking around at lowering springs and I just dont know which way to turn. Reason being is that I see 2 inch drop springs and then 5 inch and im hearing drop springs still give you rake (which I dont want)
I have been customizing cars for a long time. My question is would it be easier to cut the springs to get the proper drop. I do not hack springs with tortches or even big grinders, I cut them with a diamond blade on a dremmel, taks longer but the spring does not heat up and the cut is completely clean.
also in cutting them should i just cut a coil out of each spring? Or do 1 in the front and 1.5 in the rear so it evens it out. I dont want it on the ground but i cannont afford to put $300 in lowering springs if it dont give me the drop i want.
Old 16 Aug 2010, 01:43 pm
Default Re: Questions about springs
cut 1 coil from the front
and 1.5 from the rears,
if its good, you saved the 300
if not, adjust in small increments,
and i have a full set of springs,
stock,
you can have for 50 shipped,
worst case
Old 16 Aug 2010, 01:52 pm
K ill get to hacking tomorrow and let ya know
Old 16 Aug 2010, 03:07 pm
I don't recommend cutting - the springs can't sit flat without a flattened end.
Buy some lowering springs (no more than 2") and just put in the rears and it pretty well gets rid of the Butt-in-the-air look (rake).
Old 16 Aug 2010, 03:17 pm
808's Avatar
808 808 is offline
Yes, PLEASE do a search on this forum!! A member has done the same and regretted it. A couple hundred bucks will do it right.
Old 20 Aug 2010, 05:23 am
I agree as well, I picked up a used set of lowering springs from a fellow here and installed just the rear ones. Did a nice job of leveling it out!
Nothing could be finer than cruisin' the Carolinas!
http://www.carolinaptcruisers.com
New guy here with some questions heifetz17 Sound and Security Forum 4 14 Dec 2010 09:49 pm
New PT, some questions YouPutz General PT Cruiser Discussions 6 07 Dec 2009 01:15 pm
New here..some questions:) willz0072002 General PT Cruiser Discussions 4 07 Nov 2009 02:28 pm
Questions Questions..newbie DaShado PT Cruiser Convertible Forum 0 01 Apr 2006 12:22 am
Two Questions PTGT Redman Turbo Performance 7 26 Aug 2003 08:01 pm
