Going Up to 17's
Old 04 Sep 2010, 08:22 pm
Default Going Up to 17's
Hello,
I have searched the forum and have not found a answer.
Just bought a set of 17 inch SRT4 rims.
I am wondering if there is anything I need to do other then actually changing the wheels that I need to do, I'm going from 16's to 17's
Would my speedometer still be right?
2003 PT Cruiser GT in Black 5 Speed
Full Mopar Stage One
Diablo Sport Predator
Eibach Lowering Springs
3 Inch Exhaust (Straight Piped)
Lots Red Powerder Coating
Xenon Front Bumper
PTeazer Roll Pan
Billet Upper Grille
HID High and Low Beams (8000k/55w)
HID Fogs (3000k/35w)
Altezza Tail Lights (carbon fibre look alikes)
Leather Neon RT Front Seats
Audio Build is Currently Under Construction.
Old 06 Sep 2010, 04:09 pm
Default Re: Going Up to 17's
I had 16 inch on my Limited Edition and then went to the GT's 17 inch wheels. I went with 205x50ZR17 tires and the speedometer is almost perfect.
Old 14 Sep 2010, 11:15 am
You should be good as long at the overall diameter has not change then the MPH will be the same, which means you have a larger diameter rim and a lower series tire. Just a guess but your 15" are 55/60 series tires and your 17" 35/40 series
New Yoko's: 215/50/17's for my GT bados Wheels, Tires, Suspension 0 19 Aug 2007 05:00 pm
GT 17's PT Charlie Wheels, Tires, Suspension 4 07 Oct 2005 11:25 am
Best way to shine chrome 17's? PTucker The Detail Shop 4 07 Dec 2003 01:48 am
17's in Front...18's in Rear Meeks Tech & Performance Forum 4 23 Feb 2003 01:35 am
