Question after Wheel Bearing Replacement
Old 08 Sep 2010, 06:27 pm
Default Question after Wheel Bearing Replacement
Hi all,
Longtime lurker, first time poster. Have an '03 Touring Edition w/119,000 miles that had passenger side wheel bearings going out for a while and just replaced them this week. Checked play on drivers side and went ahead and replaced them same time. Went with the "set 49's" at AutoZone and local shop charged $30 each press off and on.
Strange thing happened on test drive though: Trac Off light and ABS light both came on on stayed on. Double checked everything and can't figure out what causing this. Any ideas?
Thanks.
Old 08 Sep 2010, 06:38 pm
Default Re: Question after Wheel Bearing Replacement
The other thread you posted on was a POLL on replacements. I started your own thread with your question.
Old 15 Sep 2010, 03:58 pm
Really? A whole week gone by and no one has any ideas?!?
Old 15 Sep 2010, 05:05 pm
Have yu tried a search to see if your question has already been asked?
Found this:
trac control & abs light staying on in dash
Poll: Wheel Bearing Replacement 2004PTGT Wheels, Tires, Suspension 141 16 Feb 2011 09:41 pm
Wheel Bearing / Hub replacement parts soccrstar Tech & Performance Forum 0 27 Mar 2010 02:48 pm
Front Hub/Bearing Replacement scrisp2 Wheels, Tires, Suspension 0 04 Dec 2009 12:38 pm
Wheel bearing/hub Question.. Rowdy Wheels, Tires, Suspension 0 19 Jul 2009 06:06 pm
CV shaft after hub and bearing replacement? 2004PTGT Wheels, Tires, Suspension 9 17 Jul 2008 06:51 pm
