Rear Brake Shoe Thickness?
Old 17 Sep 2010, 06:23 pm
falconut's Avatar
Default Rear Brake Shoe Thickness?
I was checking my rear brake shoes tonight. When I spin the drum, it sounds like it is lightly rubbing the pads. No squeal, just sounds like it's rubing. The pad thickness measured around 1/8" or 4 mm with a ruler. They look pretty thin, but I'm not sure what they look like new. Do I need new shoes?
Old 17 Sep 2010, 07:15 pm
Default Re: Rear Brake Shoe Thickness?
!/8 inch is pretty thin. Your probably at about half the full thickness and since they are probably glued on, there's no rivets to worry about scorching the inside of the drums so you can go a bit further before replacement. If in doubt, have them checked out for free at at brake repair facility. Just don't get fooled into buying anything you don't need.
Old 17 Sep 2010, 07:33 pm
falconut's Avatar
I suppose I can go to the parts store and look at the new ones. The shoes also have beveled edges, not sure if that's how they're supposed to look.
Old 17 Sep 2010, 07:45 pm
Not sure either since it's been a couple years since I replaced mine.
Old 24 Sep 2010, 08:01 pm
falconut's Avatar
I picked up a new set, but after cleaning off the old ones, they don't look much different then the ones on there. Just a tiny bit thicker, so I'm probably taking back the new set.
rear brake lights jacquit General PT Cruiser Discussions 1 23 Nov 2009 03:19 pm
Rear Drum Brake Swap? mopar1cjh Turbo Wheels/Suspension/Handling 1 06 Aug 2009 09:15 pm
Rear brake noise... Striker Wheels, Tires, Suspension 4 04 Jun 2006 12:01 pm
For Sale: REAR BRAKE SHOES blue Classifieds: For Sale/Trade 0 01 Aug 2005 10:15 pm
Rear brake kit Todd TCE Turbo Wheels/Suspension/Handling 2 16 Nov 2004 07:56 pm
