Wheel question
Old 03 Oct 2010, 07:15 am
SCBluePT's Avatar
Default Wheel question
Would it be possible to put my tire pressure sensors into the 2003 GT 17" wheels?
Old 03 Oct 2010, 07:51 am
Default Re: Wheel question
Can you swap TPMS to aftermarket wheels?
http://www.fitfreak.net/forums/tire-...et-wheels.html
Old 03 Oct 2010, 07:55 am
SCBluePT's Avatar
I know I can put them in aftermarket wheels but I want to use the stock GT wheels.I was just wondering if anybody knew if they could be used in the earlier wheels.
Old 06 Oct 2010, 06:14 pm
SCBluePT's Avatar
Anybody?Is there a way to disable the system so I can use any wheel that I want?
Old 06 Oct 2010, 07:20 pm
You are asking a technical question that most people would have no idea of the answer. Not many people want to do away with the TPMS system and wouldn't have the fainted idea how to disable it. Have you looked for any fuse in either box that would give power to that system? It might me as easy as pulling a fuse out.
Old 06 Oct 2010, 07:38 pm
808's Avatar
808 808 is offline
A member of this forum works for a dealership. I don't recall his username at the moment so hopefully he sees this thread.
Old 06 Oct 2010, 07:44 pm
cruserdad1976's Avatar
I do know that on the wife's KIA she bent a wheel and I had to get a new steel wheel and they just moved the TPMS to the new wheel they did have to re activate it so I cat see why you couldn't do it on a cruiser
Old 06 Oct 2010, 07:47 pm
Freezinghot's Avatar
Theres no reason you couldn't do it. Youll need to take the tire off, drill holes in the rim and countersink it so that it will fit flush, but still have contact. Its definitely a big project and in my opinion, not worth it when you can just push your tire with your foot to check it.
The two valves you will need
inside shot of the hole
after install
Sensors might cost you upwards of 150$
04 graphite(vroom!) N/A Limited 110,000 miles -original owner. Custom short ram intake ( CGS motor-sport pipe, specter open-end air filter, specter breathing hose),OEM spoiler, Pioneer receiver ,10" bazooka sub,Blue LED interior lighting, Bosch +4 plugs and Accel super stock 8mm universal plug wires.
Old 07 Oct 2010, 07:44 am
vermontpetey's Avatar
I tried to do this on a Suburban, and ran into issues. After changing wheels, and then ordering different sensors, I have up and lived with the light. When winter came, I switched back, did the "relearn" procedure, and was back in business.
I can't speak to the PT specifically, so it may work just fine...
You're never too old to have a happy childhood..
Wheel bearing/hub Question.. Rowdy Wheels, Tires, Suspension 0 19 Jul 2009 06:06 pm
wheel Question 07PTowner Wheels, Tires, Suspension 6 17 Apr 2008 07:55 am
wheel diameter question ptbluegenes Wheels, Tires, Suspension 11 01 May 2004 07:12 pm
4 Wheel Disc Question... Bloxstudios Tech & Performance Forum 12 21 Mar 2004 08:13 pm
Tire /Wheel Question GTPT General Turbo Discussions 10 23 Sep 2003 02:00 am
