Will Toyota Avensis Wheels fit my Cruiser?
Old 05 Oct 2010, 05:27 am
Default Will Toyota Avensis Wheels fit my Cruiser?
Does anyone know if a set of wheels from a Toyota Avensis (2005) will fit my 2001/02 Pt Cruiser Classic? Dimensions are 205/55-16, ET 45, 5x100.
Old 05 Oct 2010, 05:38 am
Default Re: Will Toyota Avensis Wheels fit my Cruiser?
Welcome to the Forums.
Very unlikely.
I saw a list of compatible wheels - there were some VW, a couple from GM, but no Toyotas.
Old 05 Oct 2010, 06:19 am
Ok, what is the crucial point here then? The Cruiser also has 5x100 bolt pattern (I think?) and the wheel dimensions 205/55-16 are the same. So then I guess it must be the "ET 45" thing that spoils it? (don't actually know what this means..)
Old 05 Oct 2010, 06:47 am
The big center hole has to be right - the PT has "hub centric" wheels - meaning the center of the wheel rests on the hub - it isn't just the wheel lugs that position the tire. There is also offset - whether the back of the wheel clears the brake calipers.
Old 05 Oct 2010, 09:54 am
vermontpetey's Avatar
As long as the hub size is the same or larger, they will probably fit. That said, you may have to add hubcentric rings to keep them from vibrating, if they are different...
You're never too old to have a happy childhood..
Old 05 Oct 2010, 11:02 am
Ok, thanks for the replies guys, but I don't quite get it yet.. What is the hub size and how do I find it? And what does "ET 45" in the Toyota wheel description mean? (btw; english is not my native language either..)
Old 07 Oct 2010, 05:29 pm
You were right, they didn't fit.. I took a chance and bought the complete set of wheels with tires, and tried to install one of them on my PT, but the hub centre was too narrow.. But I guess I can use the tires anyway.
Old 07 Oct 2010, 11:43 pm
Freezinghot's Avatar
Your a lot more adventurous than most people. Ill give you that
04 graphite(vroom!) N/A Limited 110,000 miles -original owner. Custom short ram intake ( CGS motor-sport pipe, specter open-end air filter, specter breathing hose),OEM spoiler, Pioneer receiver ,10" bazooka sub,Blue LED interior lighting, Bosch +4 plugs and Accel super stock 8mm universal plug wires.
Old 08 Oct 2010, 01:46 am
808's Avatar
808 808 is offline
Thumbs up Re: Will Toyota Avensis Wheels fit my Cruiser?
Originally Posted by Freezinghot View Post
You a lot more adventurous than most people. Ill give you that
Yep, lol!
Old 09 Dec 2010, 04:34 pm
TheAnt's Avatar
Can you help a feller on where you saw that list?
I'm looking for 2005 PT
15" x 6"
5 bolt 100mm pattern 10mm studs
Heck I bet I could punch all of the above in google... tryin' that.
Very unlikely.
SUV/RWD wheels on a PT Cruiser pt stunna Wheels, Tires, Suspension 3 04 Jun 2003 12:22 pm
