Rear wheel wont come off.
Old 09 Oct 2010, 01:29 pm
Default Rear wheel wont come off.
So I thought I'd put new shocks on my wifes 2001 cruiser today. Drivers side rear wheel won't come off. Anyone have tricks on getting a stubborn wheel off? I've tired kicking it, no good. I've attached a 2x4 to it and beat on it, carefully, with hammers up to my sledge. This thing still won't budge. Any tired and true tricks, or something else to try?
Old 09 Oct 2010, 02:15 pm
Default Re: Rear wheel wont come off.
Soak it with WD-40, let sit overnite.
Old 09 Oct 2010, 03:17 pm
Here's plenty to read on the same subject.
How do I remove the brake drums?
Old 09 Oct 2010, 06:36 pm
Yeah, I soaked it, gave up and put the tire back on. Will give it a go Sunday. I didn't dig too far into the break drum post. I couldn't get to the drum if I wanted to, stupid tire won't come off. I did try and hope that the cruisers weight would do it so I slowly dropped the lift until it was on the ground. Still nothing. Heres hoping the wd40 bath does it. I love the smell of that stuff.
Old 09 Oct 2010, 08:44 pm
soonercruiser's Avatar
Red face Re: Rear wheel wont come off.
Worst case scenerio, after the WD40 trick; loosen you lugs and drive the neighborhood, looking for the biggest bumps!
I drove all the way to work one day (16 miles) with wheel vibrations getting worst.
(Sure enough, in rotating the tires the day before, I had failed to torque tighten one wheel)
(Boy! That wheel must not have been rotated in a few years!)
Frank, aka SOONERCRUISER,
2011 GWE Dodge Challenger SRT8 as Show Car
Old 11 Oct 2010, 01:14 pm
I did have the thought of keeping the lugs loose and driving, looking for a bump. Don't like the thought much but I'm sure it will be affective. I'm going to give them another dose of WD40 tonight and try it Tuesday. If still nothing then it looks like I'll be taking it for a spin.
Old 11 Oct 2010, 04:34 pm
cruserdad1976's Avatar
if you use a floor jack ( and I really dont like this way) but you can rais it all the way up and with the studs almost off do the quick down almost a drop it may take a few times and you may even have to put your jack on like a 4x6 to get it higher but this will work
OR if you haev it high enoug but a board on a angle under the tire so as it comes down it will have to move OUT
Old 11 Oct 2010, 08:06 pm
Cool Re: Rear wheel wont come off.
Be sure to lets us know what finally worked.
Old 22 Oct 2010, 09:54 am
Haven't had the time to work on it. I've been soaking it the last few days with the WD40. Hope to give it a go tomorrow. I had this problem with the front tires but not as bad a couple years ago. What is going on to cause this and is it preventable?
Old 22 Oct 2010, 11:01 am
The wheel is one kind of metal the hub is another. When two separate metals are mated together for a long period of time they tend to meld/mate together. Humidity/road salt etc. would help the process.
Something to read:
Ask Automan - Wheels Stuck to Hubs
Rear wheel shims Supercharged Wheels, Tires, Suspension 7 11 Mar 2012 08:23 pm
Rear wheel bearing???? bluewagon Wheels, Tires, Suspension 1 06 Jun 2010 06:43 am
L rear wheel lock up Gtr_Tech General PT Cruiser Discussions 4 17 Mar 2010 11:16 am
Rattling noice from rear wheel ? tomkruhlmann General PT Cruiser Discussions 0 13 May 2008 03:45 am
rear wheel drive? JaxPT General PT Cruiser Discussions 17 18 Jan 2004 03:49 pm
