Hearing a thumping noise when turning in reverse
Old 10 Oct 2010, 10:45 am
Default Hearing a thumping noise when turning in reverse
I have just started to hear a thumping noice coming from the front end when I am turning in reverse. Does the blal joints need to be replaced> If so, how much should I expect to pay if I take it in?
Old 10 Oct 2010, 12:22 pm
Default Re: Hearing a thumping noise when turning in reverse
As with any car that is making this sound, there could be more than one reason for the sound. Simply go to your dealer or your local Firestone, goodyear, etc. and they will diagnose your problem, normally at no charge to you. You'll find out exactly what is wrong and how much it will cost. No guessing like we would be doing here without the advantage of seeing and/or hearing it in person.
Jerry
Old 10 Oct 2010, 12:40 pm
I am intending on doing that anyway... but I wanted to see if anyone else had a similar sounding problem and see what they dealt with.
Thanks for the reply!
Thumping noise/feeling on floor board?? jkriley Wheels, Tires, Suspension 9 27 Nov 2011 09:29 am
Whining noise when turning PTBoozer General PT Cruiser Discussions 4 01 Mar 2010 12:13 pm
Noise when turning. diamonds Wheels, Tires, Suspension 3 16 Apr 2009 02:09 pm
clutch thumping noise warpedhead General Turbo Discussions 2 23 Apr 2007 02:28 pm
Rubber/Squish Noise when turning. TSB? 1ptturbo Turbo Performance 9 17 Nov 2005 10:03 am
