Acceleration vibration
Old 12 Oct 2010, 10:57 pm
Default Acceleration vibration
Hey all new question. I have noticed when accelerating around45-55mph that i feel a little virbration going on . I can't exactly pinpoint but obviously it is under the car. Is it possible control arm bushings? I had those replaced about 3 years ago. Again it's not a violent shaking or vibrating but I know how my car runs, and I know it's there.
Thanks Lynn
2005 Pt Cruiser Convertible Touring Edition
Jvc KD-R300 Dash Unit
Kicker K35 3.5in Dash Speakers
Pioneer TS-A1673R 6.5in Door
Pioneer TS-A6963R 6x9 Rears
Infinity Kappa 12in Sub
Infinity REF5350A 5 Channel Amp
Old 12 Oct 2010, 11:59 pm
Freezinghot's Avatar
Default Re: Acceleration vibration
Where exactly do you feel the vibration? is it through your foot?
04 graphite(vroom!) N/A Limited 110,000 miles -original owner. Custom short ram intake ( CGS motor-sport pipe, specter open-end air filter, specter breathing hose),OEM spoiler, Pioneer receiver ,10" bazooka sub,Blue LED interior lighting, Bosch +4 plugs and Accel super stock 8mm universal plug wires.
Old 13 Oct 2010, 06:16 pm
No I think more where im sitting the undercarriage of the car.
Old 13 Oct 2010, 06:23 pm
SCBluePT's Avatar
Could be as simple as tires needing balanced.
Old 13 Oct 2010, 07:44 pm
I would guess its the tires not being balanced as well. Just go have a place check if the rear wheels are balanced
Old 13 Oct 2010, 09:27 pm
thanks i will check that out i know it has been awhile since i had alignment and new tires. i dont do nearly as much driving as I used to so i know the tires have not be rotated recently.
Old 13 Oct 2010, 10:06 pm
Well at least you have a place to start. Even if thats not it , its not like you would be wasting your money at least.
Old 05 Nov 2010, 06:53 am
garyerrol's Avatar
If the tires were unbalanced, why would he feel it only while accelerating. Why wouldn't he feel it in that speed range all the time?
Mine does something similar first thing in the morning. I will get a bad vibration just like tires being out of balance. However later in the day, driving the same road and at the same speed, no vibration at all. The only thing I can think of is that the tires are flat spotting aafter sitting all night.
2001 LE, Shale Green, Aftermarket Wheels, Shorty Antenna, AirRaid Cold Air Intake, Whelen Talons (amber/white) in front windshield, Whelen Talons (amber) in rear side windows, Tomar RECT25's (amber) and Whelen Slimlighter(amber) in back window. Kenwood TK-880H 45 Watt Mobile Radio, Antenex 3db antenna w/ NMO mount.
http://smg.photobucket.com/albums/v7...0PT%20Cruiser/
Ham: N9PTC
GMRS: WPQS324
Old 08 Nov 2010, 09:08 pm
ProDigit's Avatar
A loose object Resonating with the engine rpm, like the reserve tire frame?
A tire balance would make sense but then the vibrations would be heard or felt at almost any speed (between 20-90 mph).
Old 09 Nov 2010, 06:19 pm
wheelgarage's Avatar
If balancing doesnt do it, it could be one of the driveshafts. They do go bad and get unbalanced from a variety of causes. In the past, the fix was to use the Turbo ones, which I did...problem was fixed.
2005 Touring Black - Automagic....California Smog Legal
H&R Cup Kit | TSW Sakata 18x8 35ET | Nankang NS-II 235/40/18 | SPC front alignment cam - rear shim | Master Pro Rotors | Master Pro Ceramic F/R pads | Rebuilt Cylinder Head - Safety Valves and Guides | Felpro Head Gasket and upper rebuild kit | Fail-safe 195 degree thermostat | Mopar Waterpump...lol | 3rd radiator fan motor | Gates timing belt kit | WIX filters (oil, transmission) | Mobile 1 5w30 | Mopar ATF4 | Redline Water Wetter | K&N Drop-In | 4th Drive side Axle | Energy Suspension Torque Mounts | 3rd set of Torque Mounts...
Acceleration problems ConspiracyTheory Tech & Performance Forum 9 10 Nov 2014 09:26 am
Acceleration vibration guntersr General PT Cruiser Discussions 2 07 Sep 2010 10:30 pm
Acceleration problems SJGW Tech & Performance Forum 2 27 May 2005 09:19 am
uneven acceleration mo-cash General PT Cruiser Discussions 4 22 Jan 2004 11:53 pm
Hesitation in Acceleration imduke2u Tech & Performance Forum 8 06 Jul 2002 07:36 pm
