Another Grinding Noise...
Old 01 Nov 2010, 08:27 am
Default Another Grinding Noise...
This time it is not coming from the wheel itself, but from up inside the wheel well, I do believe. It happens when you go over a bump (a speed bump, for example). It is coming from the left side. When I hit the bump, it sounds like something is rubbing on something else and it makes this awful grinding sound. Anyone else ever experience this before? Thanks!
Old 01 Nov 2010, 08:30 am
SCBluePT's Avatar
Default Re: Another Grinding Noise...
Is your tire rubbing the inside of the fender well?
Old 01 Nov 2010, 08:39 am
I'm not sure, I can check the thread on the tire. I don't have the car right now so I'll have to check later. But it sounds like its coming from more of a metal/plastic part.
Old 01 Nov 2010, 09:01 am
SCBluePT's Avatar
If you look at the plastic liner inside the fender well you will be able to see if it is rubbing.
AC Fan grinding noise shonenknife Tech & Performance Forum 6 27 Jun 2013 05:59 pm
Grinding noise. PtOnAir Tech & Performance Forum 6 10 Jan 2011 09:40 am
Grinding noise front end 2002 woody Art Rigby Tech & Performance Forum 1 29 Oct 2009 07:05 pm
Grinding noise SmittysGold Tech & Performance Forum 21 20 Oct 2008 07:25 am
LF Wheel Grinding/Roaring Noise gmiller Tech & Performance Forum 4 23 Mar 2008 11:57 am
