cutting factory springs
Old 09 Nov 2010, 03:05 pm
Default cutting factory springs
I have researched alot of different drop springs. I know the springs are set up handle a weight load however , everykit i see the ride will be raked
1. if I took one coil out of the front
2. if I took 1 1/2 coil out the rear
Should this level it out....
I want it to be a bit lower but not slammed.
Old 09 Nov 2010, 03:24 pm
yaris's Avatar
Default Re: cutting factory springs
someone did it before, and after a few good bumps the coil got out of its mount, due to the fact that the coil that make contact on the supports is smaller and flat, so when you cut them the coil that will make contact will be larger and at an angle... so its not a really good idea
and will let candyman do its usual write up about springs, rake and suspension, his explantions will be clear and full of good informations about how to drop your pt the right way
Old 09 Nov 2010, 04:28 pm
Totally rice. The ride will be terrible. yaris is also correct so thst would suck. Lowering springs aren't that expensive.
Old 09 Nov 2010, 04:42 pm
ProDigit's Avatar
I bought my second hand PT cruiser with lower springs.
They even used a clamp, to lower the springs even more, and used thin tires, causing my speedometer to be off by a few mph.
I would not recommend it, because of harder driving, and because your bumper always get stuck between concrete *EDIT: (of the parkinglot logs)*. If I could do this again, I'd use the stock springs (or similar aftermarkets, perhaps use a lowering clamp on them, and use 17" wheelers (thin tires) under it.
Old 09 Nov 2010, 04:50 pm
Don't do it! Period. Listen to the advice above. Save up and buy a set of springs. They're for sale on eBay and most of the forums cheaper than new.
Old 12 Nov 2010, 10:01 pm
Send a message via Yahoo to partyd
your pt is going to be jumping all over the road and in a few months you will have balls and flat spots on your tires
just buy a set of springs
DropZone lowering springs 00-02-03-04-05-06 PT Cruiser: eBay Motors (item 300476876146 end time Dec-03-10 20:15:55 PST)
2008 Pt cruiser Touring
2004 Pt Cruiser GT
2004 Chrysler 300M
2008 Chrysler Pacifica awd
Old 16 Nov 2010, 08:40 am
If you cut the stock springs, the cut end won't have a flat end.
Just put rear lowering springs in if you want to be level - 1.5 - 2" drop in rear makes it pretty level.
Old 25 Nov 2010, 04:17 am
92awd4g63's Avatar
I cut the springs on my first car and thought i was the shiz...Then one day i was driving on the high when i heard a loud pop and the car had a nasty pull to it. When i checked it out about half of a coil had broken of the spring from were it was over stressed. I also would not recomend those cheap adjustable coilovers from ebay either. A buddy of mine had them and the spring mount broke completely off of one strut in the rear from the springs causing the car to ride like a hay wagon. I have a set of Dropzone 2" springs on my Ford Focus and they ride great, my buddy also has a set on his srt-4 and they also ride great.
03 PT GT- K&N drop in & hard pipe, Hallman MBC 14PSI, More in progress.
92 Plymouth Laser RS- evoIII 16g, 650's, 190 walbro, SAFCII, AEM wideband, 2g MAF, 3in. TBE, 20PSI.
00 Ford Focus- Daily- 2.5in cbe, ebay sri,
cutting my springs bad or good? GTcruiser23 Tech & Performance Forum 7 11 May 2010 11:45 am
03 Factory Springs, 03 Factory in dash 6 disk head unit, Rear Shelf sill available: Candyman Classifieds: For Sale/Trade 3 19 Oct 2009 01:38 am
factory subwoofer cutting out! need help! BostonBoy Sound and Security Forum 7 30 May 2007 10:50 pm
Cutting Springs...... Wicked_PT Wheels, Tires, Suspension 6 19 Dec 2005 11:45 am
Cutting my shaft turbomangt Exterior & Interior Styling 16 23 Dec 2004 12:28 am
