Rear end problem/ noise
Old 21 Nov 2010, 01:41 pm
Default Rear end problem/ noise
Hi guys new to the forum.....I have a 2001 4cyc PT Cruiser.....everything works great...The only problem that I am having is...there is a loud noise coming from the rear end.....to be honest...when I ride on uneven pavement or hit a small bump...it literally sounds like the rear end is gonna fall out from under the car.....I suppose it is some kind of bushing......any ideas.....would be greatly appreciated....
Old 21 Nov 2010, 02:38 pm
Default Re: Rear end problem/ noise
It' the bell crank that connects the two watts link. The bushings go bad and it sounds like what you describe. It's a pretty straight forward job to replace. Can be stubborn to remove as the shafts on the links are tapered. Need a good puller and a little persuasion. Good luck.
Old 21 Nov 2010, 02:53 pm
What is the part name.....
Old 21 Nov 2010, 03:29 pm
The parts catalog didn't break the bushings down, I'll post what I have here but will keep looking. Those bushings are one item that is oft replaced on the PT.
Old 21 Nov 2010, 03:35 pm
Ah, found it in the '01 service manual, called the "axel pivot busing", there is a three page section describing how to remove it. I'll PM you on the info. Here's the parts list from the manual but it again doesn't break it down.
Old 22 Nov 2010, 09:00 pm
soonercruiser's Avatar
Cool Re: Rear end problem/ noise
BE SURE TO CHECK THAT YOUR SPARE TIRES IS NOT JUST HANGIN' LOOSE!
Frank, aka SOONERCRUISER,
2011 GWE Dodge Challenger SRT8 as Show Car
Old 22 Nov 2010, 09:05 pm
SCBluePT's Avatar
Yeah,it would suck to go through all that trouble to change the bushing only to find out it was the spare tire all along.
Old 27 Feb 2011, 04:24 pm
I know it has been a while..... I did some research.....the name of this bushing is called the "bellcrank".....I looked at in a manual at a local parts house.....The on that I am replacing....is just plain worn out...I can move it very frely with my hand....I checked with all the local part houses....and no one cares it....I guess it is a dealer part....I will by online.....Thanks for all the illistrations guys.....
Old 02 Mar 2011, 12:58 am
Hmmm. Another item to look out for. We just bought a 2006 and there was a clank in the back but I found that the jack had not been stowed correctly. The crank/wrench has its own pocket. Also it sounds like the hatch has a minor rattle from time to time, but I have not tracked that one down yet.
John
2006 Base. No mods yet. Purchased 2/2011 and in need of some TLC.
Old 17 Sep 2011, 11:46 pm
Turned out that the rattle was from the way the spare tire was retained. I removed it and put it all back together correctly and the rattle is gone.
Just as soonercruiser suggested.
John
Noise in Rear End sycho_kitty Wheels, Tires, Suspension 4 19 May 2010 10:11 pm
Rear Window Noise nmrickie PT Cruiser Convertible Forum 6 15 Jun 2009 11:36 am
Knocking noise from rear end Ctown General PT Cruiser Discussions 9 22 Nov 2005 06:08 pm
Rear end noise... sakigt General PT Cruiser Discussions 5 29 Oct 2003 07:16 pm
clunking noise from rear chrisjensen Tech & Performance Forum 4 02 Mar 2003 06:00 pm
