Sway Bar
Old 02 Dec 2010, 05:32 am
WolfmanG's Avatar
Question Sway Bar
Is installing an anti-sway bar a good idea or does it just make your engine compartment look tough. I've been doing some research on them and considering putting one in. I have an 07 Touring edition. Should i install one or is the suspension already made for curves since it's a Touring edition?
-Danny Wolfman G
Old 02 Dec 2010, 08:21 am
Default Re: Sway Bar
It seemed to help in mine. You have the lower bar which keeps everything together in tight turns and the upper keeps the top together (in non-technical terms). It's only a feeling but if you like to go around turns a little faster than normal, it seems to help....and it doesn't look ad either.
Old 02 Dec 2010, 01:39 pm
After '02 Chrysler eliminated the rear sway bar. Chrysler says they intergrated a sway bar into the rear axle, but that's a lie because the rear axle part number is the same for all models, including the '01-'02 models that came with rear sway bars. Unless you throw a lot of money at the suspension the PT, touring or not, will never be a car for the curves.
What you are talking about is a strut bar. You'll notice a bit quicker steering and it'll tighten up the front end a little. It's a good mod.
Old 02 Dec 2010, 06:10 pm
xwing777's Avatar
Theres some confusion going on here.
The bar under your hood is called a strut bar. It does help stiffen the front some while looking good too.
The bars under the car are called sway bars and normally can not be seen. All have factory fronts but only early years have the rears. Chrysler says that the later models have them built in the rear but is a lie as the same part number is used for both.
You can buy just the rear bar but need a mounting kit or find a junkyard to rob the parts needed. When you add the rear it does help a lot but be careful on sizes and keep them matched as it will effect understeer/oversteer/netural depending on what you want.
Old 02 Dec 2010, 07:19 pm
WolfmanG's Avatar
that's cool, thanx for the info guys.
-Danny Wolfman G
Old 27 Dec 2010, 09:12 pm
WolfmanG's Avatar
is it hard to install a strut bar?
-Danny Wolfman G
Old 27 Dec 2010, 10:20 pm
If you are talking about under the hood, no, it is just taking the nuts off of one of the struts, bolt the bracket on and doing the same on the other side. There is a torque spec, but I don't remember what it is, maybe chromenut can chime in.
Old 28 Dec 2010, 01:17 am
...I'm just a blathering idiot...
Old 01 Jan 2011, 08:50 pm
WolfmanG's Avatar
so i don't have to worry about the strut falling or anything like that?
-Danny Wolfman G
Old 01 Jan 2011, 08:57 pm
The torque for the upper mounting bolts is 25 Ft-lbs. No you don't have to worry about the strut falling because your not lifting the car off the ground and your only loosening 2 out of the 3 nuts on each side.
sway bar help DPHC Wheels, Tires, Suspension 4 22 Jul 2010 12:54 pm
BTG Sway Bar strangelove Turbo Wheels/Suspension/Handling 11 02 Oct 2005 07:37 pm
Sway Bar 01-03 Paw General Turbo Discussions 20 25 Mar 2005 04:30 pm
Sway bar quicksilverdon Wheels, Tires, Suspension 8 04 Feb 2005 08:47 am
Sway Bar.....again drew622 Tech & Performance Forum 4 26 May 2003 11:29 pm
