Rear Brakes 03 PT HELP HELP HELP
Old 22 Dec 2010, 08:41 pm
Default Rear Brakes 03 PT HELP HELP HELP
Ok, I am running a 2003 PT Stander no bells or anything like that.
Went to remove the rear wheel to do the brakes and find I have disk and Drum... both
Now.. I am like... ahhh... Help... When I went the auto store they gave me just the disk brakes....... Now what do the Drums do? the E brake?
Thanks... Need to know if I need to replace the drums as well... or just remove them and run off my disk brakes on the rear.......
thanks,
Brandon,
Old 22 Dec 2010, 09:51 pm
Default Re: Rear Brakes 03 PT HELP HELP HELP
The shoes are for your parking brake, they should last forever. Your stopping with the front and rear disks and those are the only ones you should have to change.
Old 23 Dec 2010, 09:09 am
I hope you got ceramics to cut down on brake dust on the front.
Old 01 Jan 2011, 09:32 am
VNT's Avatar
VNT VNT is offline
I assume you have disc brakes
There I belive were two, one for the GT and one for Touring, rotors are different width so pads ae different thickness and calipers are different so get the correct parts.
Your e-brake is a pair of shoes which contact the area in the "hat"
Mine delaminated from the steel backing plates. I bought new -brake shoes and the hardware kit(clips and springs) to repalce them along with new rotors and pads.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 04 Jan 2011, 01:54 pm
Only front disks are different - thicker for Turbos. I am quite positive there are only 1 thickness of disk for the rear - you either have drums rears or rear disk (with a parking drum brake hidden).
Old 09 Jan 2011, 08:56 pm
VNT's Avatar
VNT VNT is offline
No
There is a disc brake for the touring version that was an option.
I did my rear disc brakes in on my 2003GT in 06. I got rotors and pads. The GT rotors are thicker and the pads are thinner by like .060. They gave me the correct rotors but the pads would not fit. I had to take them back to Advance auto and get the correct pads.
They call them out as GT perf package with 4 whl ABS Wagner MX782
Touring with 4 whl ABS Except Perf Pack Wagner MX759
THe GT rotors are .470" thick and the others are .350
It is covered on page 5-14 of the FSM on rotor thickness, 9mm vs 12 mm.
VNT
Rear Brakes Wienerdog General PT Cruiser Discussions 5 10 May 2009 08:31 pm
Rear Brakes pt4cec Wheels, Tires, Suspension 1 04 May 2009 04:15 pm
Rear Brakes wazzzzman Tech & Performance Forum 7 09 Oct 2008 04:42 pm
rear brakes robin Wheels, Tires, Suspension 2 19 Mar 2007 09:13 am
rear brakes robin General PT Cruiser Discussions 2 19 Mar 2007 09:01 am
