replacing stud on front wheels
Old 23 Jan 2011, 05:51 pm
Default replacing stud on front wheels
whats the best way to replace the studs ont the front wheel,Im changing the brake pads and have one stud broken and one that will break when I remove the tire to change the pads,thanks Howie
Old 23 Jan 2011, 06:04 pm
Default Re: replacing stud on front wheels
You'll see behind your rotor a black dust and dirt shield. That has a notch cut out of it to allow you to pull the lugs out. I believe it's at the top side, so spin your hub around until the lug matches that cutout and you should be able to get it out that way. All the manuals state that hammering on the lugs can cause your hub to shift and damage your bearings so I'd not go at it with a sledge hammer. I actually bought a hub and gear puller off ebay for like $9 that works great for pulling the lug bolts.
You can read more on this here on the forums.
I've not gone through it, but here is another instructional on ehow.
Old 23 Jan 2011, 07:11 pm
Thumbs up Re: replacing stud on front wheels
thanks for the quick reply,that makes me feel better,have a good one bro
Replacing front door speakers evolution1971 Sound and Security Forum 2 15 Feb 2009 11:19 pm
Replacing front passenger seat. astroman71 General PT Cruiser Discussions 1 01 Nov 2008 06:34 pm
Replacing front brakes tm05cruiser General PT Cruiser Discussions 7 21 Apr 2008 10:24 pm
Suggestions?? replacing wheels on 2001 shroomfind Wheels, Tires, Suspension 2 25 Jun 2007 07:13 am
Replacing front tires - stick with H rating? coolvirus Wheels, Tires, Suspension 10 17 Feb 2005 05:54 pm
