Front Ground Straps
Like Tree4Likes
Closed Thread
Old 21 Mar 2011, 08:06 pm
Default Front Ground Straps
Could someone please be kind enough to post a couple of close-up photos of how/where the front ground straps are attached to the struts to prolong wheel bearing life? I looked in the parts catalog and didn't see any listing for an actual Chrysler part number. Would anyone happen to have the actual Chrysler part numbers, or some actual dimensions and terminal sizes, so I could fabricate myself a set of these?
Thanks,
Steve
Old 21 Mar 2011, 08:34 pm
Default Re: Front Ground Straps
This is the best shot I have but you can see it's attached to the upper bolt on the strut and then to the body. I don't think you have to as exact as your trying to make it, it's just a ground strap so a little longer or shorter than the actual strap won't hurt as long as it make good contact.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 22 Mar 2011, 08:56 am
You don't need part numbers for this. Just call or go into your Chrysler parts department and tell them what you want. Now that you have Crewzins picture you can be very eloquent when describing it to them. You can even print Crewzins pic and take it in with you.
Jerry
Old 22 Mar 2011, 10:06 am
Thanks, guys! I appreciate the info.
Old 23 Mar 2011, 08:40 am
how does a ground strap prolong wheel bearing life?
Old 23 Mar 2011, 09:26 am
cruserdad1976's Avatar
by keeping the static electricy away from the bearings--im not sure it is proven but the big tow motors at my work are now all electric and they drag a ground strip on the floor so hey who knows
Old 23 Mar 2011, 02:57 pm
Darn. I should make a sticky on just the ground straps becuase it's asked so much.
Please read....
ground wires from body to front struts?
Old 23 Mar 2011, 04:39 pm
HEY CRUZEN what do the ground straps do on the frount of the PT and whay is it called a PT and is it better than a HHR and why is a HHR called a HHR?????????????
mnahmnah likes this.
Old 23 Mar 2011, 04:40 pm
did i mention you can do smileys in the quick post
just messing with ya boss
but i bet it feelsl that way some times
Old 23 Mar 2011, 04:41 pm
wait i left one out
HEY MY MPG SUCK whats wrong with my PT
Closed Thread
ground wires from body to front struts? jacarc1 General Turbo Discussions 16 09 Aug 2014 12:34 am
where to ground amp bhunt41 Sound and Security Forum 5 29 Aug 2011 03:14 pm
Ground Wires? psychejim6077 Tech & Performance Forum 10 10 Jan 2011 10:04 am
N/A Hyper ground KingKole02 Tech & Performance Forum 12 20 Jul 2005 08:23 am
where to ground my amp CruiserDan Sound and Security Forum 6 17 Dec 2004 03:43 pm
