Brake Bleeding
Like Tree8Likes
Old 24 May 2011, 09:11 pm
Question Brake Bleeding
Very confused. I am going to bleed the brake system as I just got new brakes put on and car has 94,000 miles.
I am reading the manual and I am confused.
It says to start at the master cylinder which I get but quoting from the manual it says"remove cap from master cylinder and fill reservoir with brake fluid"
1st question: Why am I adding new brake fluid to the old brake fluid in the master cylinder?
I am using a plastic bbleeder kit and once again to quote from the manual "have a clear container partially filled with clean brake fluid, begin by bleeding the master cylinder."
2nd question: Why does the reservoir that will be catching the old fluid have to be partially filled with new brake fluid?
If I am bleeding it I don't get why there should be fluid in it when you start.
Next problem. The manual says once I move on to the first wheel "place one end of the hose over the bleeder valve and submerge the other end in brake fluid in the container"
3rd question: Again why existing fluid in the container when you start to bleed.
Is this done to lessen the chance of air getting into the valve?
2005 Pt Cruiser Convertible Touring Edition
Jvc KD-R300 Dash Unit
Kicker K35 3.5in Dash Speakers
Pioneer TS-A1673R 6.5in Door
Pioneer TS-A6963R 6x9 Rears
Infinity Kappa 12in Sub
Infinity REF5350A 5 Channel Amp
Old 25 May 2011, 12:31 am
Default Re: Brake Bleeding
Yes. And you keep the master cylinder topped up for the same reason.
Old 25 May 2011, 07:53 am
VNT's Avatar
VNT VNT is offline
here is the easiest way.
Get a couple small containers of new Dot3 or Dot 4 fluid. Castrol has some
Get a turkey baster.
Open the reservoir and suck out all the old crappy fluid in the reservoir(why waste time pumping this crap through the lines and calipers/wheel cyinders.
Fill the reservoir with new fluid.
Get a helper.
Crack the bleeder on the passanger rear side. Note mopar penetrant sprayed on the bleeder valve helps get them loose, dont reef on them or you might brake them off and now have a big mess on your hands.
Anyhow crack the bleeder and have your helper push the brake pedal down and hold it. then close the bleeder and tell the helper to lift on the pedal. Repeat this process. Do this until clean clear fluid comes out. I just use a 10mm wrench and a small cup to catch the fluid as it squirts out when your helper( my wife is a great assistant presses the pedal. Oh show your wife the old crappy fluid, they will be more responsive next time to drop what they are doing to assist, especially when it is their car
Anyhow go back the reservoir and top it off, dont forget to put the cap back on too. Go to driver rear and repeat the process and then the pasanger front and driver front. Dont forget to keep the reservoir topped off. You can easily use 32 ounces of fluid to flush out all the old fluid.
I do this on every car I own every other year. Your brake hydraulics will last a lot longer and you wont have to worry about brake fade because of moisture. Also once or twice a year use the baster to suction out the fluid in the reservoir and top it off with fresh fluid. Note too on some of the stick cars the reservoir is also common for the clutch hydralics so having clean fluid in that will help. My 2003 they are seperate but I freshen up the brake fluid in that a couple times a year too. Brake fluid is cheap.
Doing this is a good maintenace practice.
Also buy a seperate turkey baster and use it for your power steering fluid. In this case it uses ATF+4. I freshen the PS reservoir a couple times a year too.
Your rack will thank you.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 25 May 2011, 08:14 am
Yep, air is bad. Your pushing out the old fluid so you need to make sure the M.C is full else you'll be burping air out.
Adding fluid to your drain bottle lessens the chance your suck up air that way. Honestly I've never done that and never had a problem with it.
Bleeding breaks is a simple job and after you've gone and done it you'll see how easy it is. It's a two person job for sure.
Old 01 Jul 2017, 05:09 pm
Brake bleeding is NOT a two ''person'' job , one man can do it, and usually there is no need for fancy equipment . There are many ways and methods and its ''brakes'' not breaks ! But, in may case , all sorts of problems .. I am using a HF vacuum system ..which is OK .. but , I have gone thru a gallon or more of brake fluid ....
Back in the 60s, we used the old ''pump 'em up - hold 'em down'' system , no plastic hoses, no catch cans, NOTHING ..
And the job took about 2 to 4 minutes !
Those were NOT the days , much better to use the gravity system with clear tubing and containers(clear, NOT opaque) .
The good ole gravity system is not working with this old cruiser - particularly in the rear .. I am expelling so much air that I think I have an air leak somewhere ..
Old 01 Jul 2017, 07:04 pm
There is to much basic information lacking in the very first thread for anyone to really help this guy...
A few more question perhaps should have been asked before giving the information about what and how he personally should proceed with what ever his PT Cruiser is and why he is doing it?????
Old 01 Jul 2017, 07:11 pm
VsandFords's Avatar
OLD THREAD!!!! Back away slowly and quietly.
Don't make eye contact.
rckstein and NitroPT like this.
Old 01 Jul 2017, 09:07 pm
rckstein's Avatar
I wouldn't worry about it, the OP posted about his issue over 6 years ago certainly he's got it fixed by now
Old 01 Jul 2017, 10:08 pm
Handy_Cruiser's Avatar
rckstein, NitroPT and JonN like this.
Old 02 Jul 2017, 02:06 am
Carnut's Avatar
Oh gee, I didn't know there was a rule against resurrecting old threads.
I personally would have preferred to post to an old thread if the topic was similar to something I wanted to post about.
Kind of a conservation of post topics thing I guess.
George H. McDowell
Wichita, Kansas
mailto:carnut@carnut.com
http://www.carnut.com/
FB https://www.facebook.com/george.c.mcdowell
My 2005 PT Cruiser GT Convertible Project
Tips on bleeding the radiator? briancpearce Tech & Performance Forum 5 23 Aug 2010 05:17 pm
bleeding getrag slave thumperz Tech & Performance Forum 0 28 Nov 2009 03:19 pm
Bleeding the @#$%!*# Brakes... sifu_scott Wheels, Tires, Suspension 6 18 Aug 2009 01:54 pm
clutch master cylinder bleeding directions? termanpt83 Tech & Performance Forum 1 01 Feb 2009 08:00 pm
Bleeding the clutch opelenvy Tech & Performance Forum 1 15 Oct 2008 02:27 pm
