Installing Strut Tower Brace
Old 30 May 2011, 09:49 pm
Default Installing Strut Tower Brace
Rather than redirect you to my mod bible entry at PTCrew, I thought I'd just post this here for your reference.
Edit - note that my instructions are for an '06 GT Vert, but you should be able to use them for other
year models, both Turbo and NA. See step 23 below, plus follow-on materials in this thread, for specific torque values for your year of PT!
A step-by-step guide to an easy installation!
Parts needed to complete this project:
1 - Freedom Design, APC or similar chrome strut bar, specific for PT Cruiser applications
1 - Modified Speed Control Servo Mounting Bracket (for Turbo model only)
In this HOW TO, the work is being done on a 2006 PT Cruiser GT Convertible, however the strut bar purchased and used here fits all PT Cruiser Turbo and NA models.
Tools needed to complete this project:
1 - ratchet set, with 10mm and 13mm sockets
1 - adjustable multi-angle/flexible socket adapter (for those tight spaces)
1 - torque wrench that reads either Newton Meters and/or Inch/Foot pounds
DISCLAIMER -- the author of this HOW TO is not responsible for any damage of malfunctions that you may incur associated with this HOW TO. I simply am making suggestions in this project, if you feel you wish to take another route on yours, feel free to do so. The author is not a professional photographer, so if his pictures look odd, well, that might be because he is odd! The author is not a professional mechanic, so if he uses the wrong terminology and leads you astray, well, get over it, he's just a hack trying to do his best with his own PT and offering suggestions. No animals were harmed during this project. This project is low-fat, low-cholesterol, and will not cause genital warts. Use of this How To is up to the reader, if you don't like it, don't follow it. If you do and wish to tip said author, PM me and I'll give you my PayPal account. Author is NOT connected to Race and Street, or Snap-On Tools...
DURATION: Less than 1 hour if you are all set up and ready to rock....
PROCEDURE:
First, I offer up a photo of the "before" engine compartment, highlighting the mounting points for the front strut bar. Yes, that's right, you can't see a darned thing! If you look closely in your engine compartment, you will readily find the mounting points for the driver's side, but the passenger's side is somewhat hidden by a bunch of things on a bracket thing with another thing on it with some cables coming from it. Well, that's the Speed Control Servo Mounting Bracket - I looked it up to find out what the heck it was called, so believe me, that mouthful is it's name.
1. Loosen up the two nuts holding the Speed Control Servo Module in place. Carefully lift this unit up, but do not pull hard, just free it from it's mounts. These are 10mm nuts.
2. Remove the bolts holding the Speed Control Servo Mounting Bracket. Gently, and carefully, slide the bracket slightly below the Servo Unit, towards the firewall, and lift it out. These are also 10mm nuts.
3. Be careful not to pull hard, you have three vacuum control valves mounted there. Those will be removed shortly.
4. Try, if possible, not to remove the vacuum hose from the side of the Servo Unit, it is connected to the Vacuum Well and if you remove it, you will drain all of the vacuum from the well, requiring you to build that up later on when you're done.
5. Be very careful of this power connection, it is on a really flimsy mount and can be busted off with ease.
6. Make darn certain that you don't pull off the ground strap, nor that you push and/or pull on your Air Conditioner lines in excess. You can cause yourself more work later on if you're not gentle.
7. Pre-check fitment of your strut bar and bracket assembly. Just do a quick once-over to insure that you have it set up correctly for install. Make sure you have the strut bar facing the correct way - if you bought the Race and Street strut bar, the Freedom Design label should be facing you when you're installing it.
8. I've highlighted the nut/bolt positions on the mounting bracket - these bolts extend up a good way and are mounted loosely to the fender well, pay close attention that you DO NOT damage the rubber pad that is below the bracket when you remove it. You will have to reuse this pad and the ferrules that are installed in it.
9. Now that you have all of that loose, gently roll over the Speed Control Servo Unit so that you can get to the data buss connector. On mine, there is an orange locking tab that must be pulled gently to the side, allowing you to put pressure on the black clip holding the connector in place. So, slide that orange locking tab to the side, as shown below, then hold down on the black clip, while pulling on the connector to pull it apart. This doesn't require a lot of strength if you've got the tab unlocked. Remember, press DOWN on the black clip shown to the left of the orange tab, do not try pulling or prying it up! Once you've got that disconnected, store the wire down somewhere out of the way.
10. Okay, you've got the bracket off, and the Servo dismounted, now you need to dismount the three vacuum valves from the bracket. As shown below, press in, as in away from the plug, on the tab at the top while pushing down on the plug. It should slide out of the bracket with relative ease. Notice in my photo the order of these valves, this is the factory order, 1-3-2... I do not know why they are this way, but I suggest not mixing them up so that when you reassemble you put them back in the same order. You will notice in all of my pictures that I've color-marked all connections to insure I get them back in place properly during reassembly.
11. Now you've got your OEM bracket free. You'll need to clean it up so that you can reuse the rubber pad and ferrules, that is if you're not going to modify it for the turbo mount...
12. I suggest at this point that you figure out a way to move the Speed Control Servo Unit out of the way. I found it simple to bungee it to the hood hinge as shown below. Item to note, again, try not to pull that vacuum line from the Servo Unit.
13. Now you've got to pull that rubber pad off the bottom of that bracket to reuse it.
NOTE: If you're going to modify your own bracket, that being if you have a Turbo vs. NA, then you don't need to do steps 14 - 16. You will find a separate section down below that describes the method to modify the existing bracket to fit the strut brace on the Turbo PT. If you purchased the strut tower brace with the cutout bracket for the Turbo PT, then you need to follow all the following steps.
14. You need to press the protective ferrule out of the rubber pad by pushing it back up through the bracket. I found just the right size flat tipped screwdriver that was perfect for the job. Took all of 10 seconds to remove the ferrules.
15. Now to remove the rubber pad, you have to push the rubber nipples (now stop giggling) back through the bracket. I found that using a flat tipped pair of pliers worked wonders. Try your best not to either pull the nipple off, or to damage it in any way...
Old 30 May 2011, 09:50 pm
Default Re: Installing Strut Tower Brace
16. Now do the reverse, push the nipples through the bottom of the new bracket, then slide the ferrules in place, insuring that the flat top of the ferrule faces up towards the hood of the car and is not underneath the rubber pad. ITEM TO NOTE - you can tell from these photos that a significant amount of metal has been removed to make room for the strut bar - be very careful in handling the new bracket as the arm that supports the three vacuum valves is VERY EASY TO BEND (what, is that the voice of experience that I hear?).
17. Loosen up the two nuts that your strut bar will mount on - these will be obvious when you test fit the bar, but just in case, a word of advice - don't loosen the bolt closest to the firewall, there's no need to remove that one and it'll just cause you more work. These are 13mm nuts.
18. Install the new Servo Unit bracket where the old one came off of, do not install the vacuum valves nor the Servo yet, and leave this in place but not bolted down all the way. Again, be careful around the air conditioner hoses and the ground wire.
19. Install your strut bar, making darned certain that you have cleared all obstacles. Mount it and put on the nuts holding it in place, but do not tighten them yet. Make absolutely positively certain that you do not restrict the throttle cables going to/from the Speed Control Servo, and there is a power connector on the firewall, on the passenger's side, that is in a very flimsy mount, make sure you have cleared these before tightening anything!
20. This is a view from behind the strut bar showing how I've rerouted the cables to/from the Speed Control Servo, placing them below this power connection. They are unhindered now, and fairly well hidden.
21. On the driver's side, you have the cable harness coming from the Power Module, make sure you don't affect this at all. I suggest placing it inside of the strut bar, towards the fuse box, as I've done in this photo. That seems to cause the least amount of strain to the wiring harness, yet still allows access to all fuses, etc.
22. Just in front of the driver's window, there is a pod of vacuum lines that you need to make sure are clear. Gently pull them down below the level of the strut bar, you can tuck them behind the strut bar when you are done.
23. Now you've got the bracket installed but loosely held in place, and you've got your strut bar installed, but also loosely in place. Go ahead and tighten the bolts for the strut bar. I suggest starting with the one closest to the Servo Unit on the passenger side. All four of these bolts will be torqued to 26N-m, or 19 ft. lbs. DO NOT OVER-TORQUE THESE! Snapping one off would be a bad idea.
Note - this torque value is for the 2006 year model. Other year models have different torque values, please see references below in this thread!
24. Now before you tighten the nuts holding the bracket in place, reinstall the three vacuum valves back on the bracket, then tighten the nuts holding the bracket in place. These need to be torqued to 7N-m, or 60 in. lbs. Again, do not over-tighten these. Again, make sure you've not got the ground strap trapped under the bracket, and make sure you treat your AC hoses gently. Reconnect the data buss to the Servo Unit, and tighten those nuts, to the same torque value listed above. Make sure your vacuum connection to the Servo Unit is still in place.
That's it, you are now complete, and it's time to clean up. I've got an assortment of pictures below of the finished product. This is a simple project, and well worth the cost in time and money!
Old 30 May 2011, 09:54 pm
Passenger side, showing the newly installed bracket, all cables, wires, and electronics are clear and out of the way. Lines have been rerouted above the Speed Control Servo that were previously below it. There is more room with them on top and behind the unit.
Driver's side strut bar mounting positions.
Passenger side - a final look at the throttle cables rerouted in a more comfortable manner.
Driver's side - a final look at the vacuum lines rerouted below and behind the strut bar, in a more comfortable positon.
Last look - the completed strut bar mod:
Old 30 May 2011, 09:55 pm
Note - brought up by harleyrider86, if you don't buy the Freedom Design's strut bar with the modified mounting bracket, you can see from the photo comparing the OEM and the modified one that this would not be very difficult to do on the OEM bracket, assuming you've got the proper cutting tools. I've traced along the lines similar to what harleyrider86 did with his bracket.
Old 30 May 2011, 09:56 pm
I have the Maintenance/Service Manuals for all year's of the PT's, so I looked through them and sure as shootin, they are different.
So I'm going to paste my references here plus the torque settings that I found so that you don't do the wrong thing in installing your strut bar.
2001-2004 Manual states, "Strut-to-tower nuts should be torqued to 34N-m or 25ft. lbs.", while the 2006 Manual states, "Strut-to-tower nuts should be torqued to 26N-m, or 19 ft. lbs.".
Here are my references:
2001-2004 Front Suspension Torque Specs
2001-2004 Strut Assembly Instructions
2006 Front Suspension Torque Specs
2006 Strut Installation Instructions
Now that we've seen there are differences between the years, I'd confirm your specs for 2005, and >2006 year models before proceeding. You definitely don't want to break off the strut mount bolts!
Old 20 Aug 2011, 12:56 pm
drsnutz46's Avatar
great job explaining it man. i am going to make my own strut tower brace that will not only attach at the struts but at the firewall to give it more triangulation hence more rigidity of unibody. i am also planning on fabricating an old hotrodders trick called a torque strut. simply it is an adjustable rod with poly bushings that prohibits the engine from rotating at launch or hard acceleration thereby putting more h.p. and torque to the ground rather than waste the energy with rubber motor mounts. it also gets rid of torque steering of the front end, car will then launch straight as an arrow even with your hands off the wheel, can't imagine why you'd do that except for r&d purposes which is how i came up with the torque strut. a piece we pioneered during my days at jba racing. they sold like hotcakes. you can do the same thing for rwd cars attach torque strut to motor and chassis in front and energy transfers to rear wheels instead motor trying to roll over. will take pics of buildup and keep you posted. PEACE
Old 20 Aug 2011, 01:37 pm
Something like this?
Old 22 Aug 2011, 08:29 am
drsnutz46's Avatar
that would be exactly what i'm talking about lol. i looked all over the internet and couldn't find one, i can make one for about 5 bucks and that includes materials. thank you for sharing that, most peeps have no idea how much energy is lost with axle/engine, tranny wrap up. may i ask where you got it from, and are they a reliable source for performance parts? ty again, look forward to chatting with you more.
Old 22 Aug 2011, 09:03 am
I got them from Ebay for about $130 with red powder coating. They are the Bwoody brand. They are the same as the Neon SRT4 because the PT GT has the same engine. If you want send me a PM with your facebook info so we can chat.
BWoody Neon SRT-4 / PT Cruiser solid motor mounts | eBay
Old 28 Sep 2015, 04:20 pm
Hey. Does anybody have the installation process saved? Particularly the pictures? I just ordered a tower strut brace from that Andy website getting the freedom bar. I'm waiting on confirmation that it actually shipped hoping it is still in stock...
--2006 pt cruiser non turbo owner. Completely stock... For now.
STRUT TOWER BRACE soonercruiser Turbo Wheels/Suspension/Handling 10 21 Dec 2014 02:21 pm
Strut Tower Brace CranTerri Wheels, Tires, Suspension 7 05 Oct 2010 06:31 pm
strut tower brace ptsurge Classifieds: For Sale/Trade 12 10 Feb 2006 11:56 pm
GT Strut tower brace GTSteve Tech & Performance Forum 10 25 Sep 2003 11:50 am
STRUT TOWER BRACE namvetmike General PT Cruiser Discussions 3 30 Jul 2003 03:45 pm
