sways in the wind
Old 29 Dec 2003, 05:33 pm
Default sways in the wind
What cause's a car, any car to sway from side to side like the wind is blowing? but no wind is blowing? Worn springs? shocks/struts?
maybe this should this be in the non-PT forum?
Old 29 Dec 2003, 06:05 pm
Sounds like springs and/or shocks/struts are worn out. If the car has a leaf spring in the rear that could be shot also. Try this, on each corner of your car push down hard and let go. First, you should feel good resistance when you push down, second, the corner your pushing on should rebound back to normal height. If it oscillates up and down before returning to normal height your shocks are no good.
2002 Inferno Red PT Limited
Mercedes Wiki
Old 29 Dec 2003, 08:49 pm
quote:Originally posted by IRPT
Sounds like springs and/or shocks/struts and worn out. If the car has a leaf spring in the rear that could be shot also. Try this, on each corner of your car push down hard and let go. First, you should feel good resistance when you push down, second, the corner your pushing on should rebound back to normal height. If it oscillates up and down before returning to normal height your shocks are no good.
Correct.
Also check tire pressure - if very low, causes "mushiness".
Old 29 Dec 2003, 09:13 pm
tires wearing unevenly??
Old 29 Dec 2003, 11:22 pm
car does not overly? bounce up and down when pushing on corners or going over speedbumps, in dips ect...
tire pressure is at spec & wearing evenly (at least for a car w/234K on it LMAO!)
For those that can remember try and picture this. Your old family Chevy Caprice Classic Station wagon loaded up for vacation. You are cruisin down the hiway at say 75mph and need to change lanes. You turn the wheel slightly to move to the next lane. 2 seconds later the car decides to start it's lane change. Before the car actually gets to where you want it, you counter steer to stop the station wagon from swaying all over the road. (sorry i was bored)
I never had a car with worn coil springs (i don't think) so i am wondering if this is a symtom of those. How about bushings? No rattling as if something is loose or worn either.
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 30 Dec 2003, 12:13 am
Still sounds like worn out shocks/struts.
Mercedes Wiki
Old 30 Dec 2003, 01:51 am
has the car always done this?
where their ruts in the road?
also with just a slight wind, my pt cruiser at 120km is all over the lane....
one other thing to check is the wheel weights ( I had a car where a weight fell of, lets just say at higway speeds the car handled like crap)
Old 31 Dec 2003, 12:24 am
it's not my cruiser but you notice it most at hiway speed.
no ruts
no shimmy or shake & tracks straight
I thought if the shocks/struts were bad it would bounce excessivly?
it's my old hoopdie w/234k on it. I may sell it anyways. I sure would like to have that LaBaron that was for sale a while back
Old 31 Dec 2003, 01:48 am
One way to find out is to take one shock off, see if you can push it down with your hand easily. If you can it's shot!
Mercedes Wiki
Old 31 Dec 2003, 03:49 pm
"Chevy Caprice Classic Station wagon loaded up for vacation. You are cruisin down the hiway at say 75mph and need to change lanes. You turn the wheel slightly to move to the next lane. 2 seconds later the car decides to start it's lane change. Before the car actually gets to where you want it, you counter steer to stop the station wagon from swaying all over the road"
i remember those days!!
Benevento moonroof wind deflector - Sold DMW Classifieds: For Sale/Trade 1 20 Dec 2005 07:48 pm
any pics of an installed s/r wind deflector? pppt03turbo Exterior & Interior Styling 7 22 Nov 2005 08:03 pm
Wind noise at 90mph turbomangt General Turbo Discussions 7 18 Mar 2005 12:27 am
Received my Weathertech wind deflectors PTRON Exterior Accessories Forum 2 23 Jan 2003 06:12 am
Sunroof wind deflectors I3pinggolfer Exterior Accessories Forum 0 13 Aug 2002 04:03 am
