Control arm bushing
Old 29 Jun 2011, 10:41 pm
Cool Control arm bushing
Does anyone know if I can use a ball joint press for removing and replacing my control arm bushing?
Old 26 Jul 2011, 04:16 pm
Gremlin's Avatar
Default Re: Control arm bushing
From what I've read in other posts it should work. I don't have a press (yet) so I was going to go with the "burn it out" approach.
White '03 GT. Mine since 2010. DIY work (read, budget): DIY cabin air filter, ball joint/control arm bushings/wheel bearing replacement, CV axle replacement, brakes, struts, K&N drop-in filter, oil pressure sensor replacement, Spark plug gasket replacement.
"But I don't want to go among mad people! Alice remarked. Oh you can't help that, said the cat, We're all mad here. You're mad, I'm mad. How do you know I'm mad? asked Alice. You have to be, or you wouldn't have come here, replied the cat."
Old 26 Jul 2011, 05:29 pm
If you are using Energy Suspension bushings the easiest way to do it is just burn the old bushings, but if you use OEM type bushings you need to press them.
Old 27 Jul 2011, 01:42 pm
Gremlin's Avatar
Ah! That is really good to know. I am glad I plan to use the Energy brand anyway. Thanks
Old 27 Jul 2011, 02:08 pm
ROCKETMAN8060's Avatar
Do TUTORIALLLLLLLLLLLLLLLLLLLLLLLLLLL!!!!!! LOL!!!!!!
ROCKETMAN8060
Old 27 Jul 2011, 02:11 pm
Don't forget to change the ball joints while you are there. If you don't have them yet I can get you a place to buy them for $21 each for the MOOG brand.
Old 27 Jul 2011, 03:46 pm
Gremlin's Avatar
True! It looks like new arms w/ball joints and bushings may be the best way for now....
Lower Control Arm (LCA) & Bushing R&R UptownSport Tech & Performance Forum 12 18 Apr 2014 04:04 pm
Control arm rear vertical bushing daytonalen Tech & Performance Forum 2 16 Jun 2011 08:51 pm
Control arm bushing timcathy Wheels, Tires, Suspension 3 13 Mar 2010 09:39 pm
Lower control arm bushing TCH Wheels, Tires, Suspension 2 13 Jan 2008 01:00 pm
Control Arm Bushing PTZCrazy Wheels, Tires, Suspension 6 08 Jun 2004 02:42 pm
