Lower control arm bolt
Old 02 Jul 2011, 10:01 pm
Default Lower control arm bolt
Tried to change lower control arms today .but cant get the bolt off . the one that goes thru the bushing . I sprayed with pb blaster the night before dont want to break off bolt . Has anyone else have trouble , would heating bolt be next thing to do .
Old 02 Jul 2011, 10:26 pm
Default Re: Lower control arm bolt
I used a long breaker bar and work each bolt back and forth but make sure you don't break it
Old 03 Jul 2011, 01:17 pm
rcktpwrd's Avatar
Put a breaker bar on it. That bolt is torqued down pretty tight and it's a pretty large diameter bolt...
Joel
2001 PT Cruiser 5-speed; 1976 Oldsmobile Cutlass S; 1990 Chevy 454SS; 1989 Chevy Suburban 2500
www.rcktpwrd.com
Old 03 Jul 2011, 05:51 pm
chigger_ns's Avatar
Yup, I would not use an impact gun on it.
It took me a couple of tries and then I put a small pipe on the end of the breaker bar.
Its amazing how a little more leverage will help you.
Once it starts it should come out quite easy.
2001 PT 5 speed Touring Edition
Eibach Pro Springs, Energy Suspension HyperFlex Master Kit bushings, 17" RTX Euro wheels, K&N drop in air filter, MotoMaster flat plate AGM battery, KYB GR2 shocks and struts, Booger standard shifter bushings, Ooogah horn.
Lower control arm LNBNDN Wheels, Tires, Suspension 2 29 Jun 2011 10:00 pm
Control arm (BOLT) Size Bluecruiser Tech & Performance Forum 0 07 Sep 2010 02:33 pm
cut off bolt for control arm richwms1 Tech & Performance Forum 10 10 Dec 2009 08:19 pm
Control Arm Bolt CAD Tech & Performance Forum 1 10 Dec 2009 05:54 pm
Lower control Arm Bushings BOLT Madturtle Tech & Performance Forum 3 10 Jun 2009 02:00 pm
