drops and problems with camber
Old 01 Jan 2004, 10:38 pm
Default drops and problems with camber
I have been reading in the srt forums, that people with drop springe over time are having problems with their camber, thus screwing up their tires, after a drop shoul an alighnment be required?
Old 01 Jan 2004, 10:59 pm
Send a message via AIM to Rolo
Someone will have to check me on this, but if you change the rake, you will throw the camber off and will need to realign it. Not only will you hork your tires, but handling during turns will suffer since the axle will no longer be upright TDC.
Old 01 Jan 2004, 11:30 pm
Definitely! If you lower it you should get an alignment, at least have it checked. A small drop may not require re-aligning but how can you tell just by looking at it. Better to be on the safe side and at very least have the alignment checked, other wise you may be buying tires a lot sooner than you though.
After I replaced my struts/shocks and springs I had the front and rear aligned. Did not need a camber kit, came into alignment without one.
2002 Inferno Red PT Limited
Mercedes Wiki
Old 02 Jan 2004, 01:44 am
after i dropped my pt, got a alignment done, and i didn't need a camber kit..
03, onyx 5 speed, custom interior, 14 tv\'s, ps2, , custom stereo, hood, bruiser front, sides, roll pan, custom exhaust,20 inch rims, air ride system, 4 12inch subs in a molded in a box, member of del val and GROUNDED 4 LIFE. vertical doors, big ass ragtop roof, 10.5 inch screen in steering wheel, move window switches to glove box, glassed a tv where the switches were, smoothed dash and painted, led tailights, tv;s in quater panel windows
FRESH TWO TONE GREEN AND SILVER , SHAVED TAILIGHTS WITH LEDS IN THE ROLL PAN...
Old 02 Jan 2004, 11:30 am
From what I've read, front drop may/may not need front alignment. Should have it checked. If it meeds it, there are kits with eccentric washers.
Old 02 Jan 2004, 11:53 am
Send a message via AIM to macster
Ditto
But I needed the front to be adjusted, I had too much toe out.
macster
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
Old 02 Jan 2004, 01:01 pm
MMM, how do I put this without offending anyone?
Perhaps the thread that asked about the forum members age speaks for itself.
PianT
Old 02 Jan 2004, 04:57 pm
I origanilly went with Progress Spring no alignment kit needed.. Later switched to Goldline Slammer Springs alignment shop was able to get car aligned without a problem.. Slotting the upper bolt hole on the strut bracket will allow you to get the few additional degrees needed.. remember that you want some neg. camber.. Last but not least I went with Air Ride Suspension so my camber will vary depending on the ride heigth that I am running. If an alignment kit is needed then any reputable alignment shop should be able get you aligned without any problems..
Kevin
