tire size help
Old 02 Jan 2004, 01:34 pm
Default tire size help
[:I] ok what does the numbers stand for. 235,240 ,245, does that have
to do with the tire height. And what about the 50 60 have to do with the width.
now if i put 18's on what would make the wheel well fill up better. It is lowered 2 " what i"m looking for is the bigger tire to give it that full look.
Old 02 Jan 2004, 01:41 pm
Check it out cruiser12
http://www.tirerack.com/tires/tiretech/general/size.htm
PianT
Old 02 Jan 2004, 10:06 pm
cruiser12,
If you put the 235's on the front it will mess up the Computer and it wont allow the car to run right and the mileage will be off and the transmission will not change correctly it goes on and on and on..... basicly see the previous posts on tire sizing.
On the front I have 205/60r15's which is the same circumference as the originals. The Cruiser is a front wheel drive and all of the computer system and drive train is at the front. The back tires I have 235/60r15's, since they are just tracking wheels and nothing is connected to them I have had no problems with using the bigger tires.
I bought 15" wheels so I could get a taller sidewall on the tires. Just don't like the lowprofile look.
[?]still wheelin'
Cruisergeo
My Website is
http://cruisergeo.tripod.com/
Old 02 Jan 2004, 11:24 pm
I'm running 225/35-19's on all 4 corners, speedometer has not been affected.. Going with a
The first set of # is the width in mm, second set is the sidewall hiegth, and of course the last # is the wheel size...225/35/19
larger diameter in the rear only becomes an issue if you have ABS.. There is a certain %window that you can fall into and not have your ABS be affected..ex. lets say a 225/35-19 in the front and a 235/35-20 in rear, overall difference is less that 2" or 2% so it will be OK.. Cruiser looking at your pics it is safe to say that you don't have 4 wheel disk and ABS..
Old 03 Jan 2004, 11:29 am
The tire rack link explains it best. I just want to add that a low aspect ratio (second number) is great for handling (in dry weather), makes for a poorer ride (less tire between you & the road). If you do snow driving a higher aspect ratio is better ("skinnier" tire cuts thru snow better). A low aspect ratio tire is also more prone to hydroplaning in rain than a higher aspect ratio tire.
Largest size replacement tire for GT wheel is... Gary04GT Turbo Wheels/Suspension/Handling 12 01 Apr 2006 10:33 pm
Does changing the tire size affect ABS? blueberrygt Turbo Wheels/Suspension/Handling 1 16 Apr 2004 09:07 pm
18x8 rims what tire size best dfunkdj Wheels, Tires, Suspension 4 15 Apr 2004 04:04 pm
The BEST street tire in a 215/17 size CraigO Turbo Wheels/Suspension/Handling 13 16 Jul 2003 03:47 pm
tire size tom Tech & Performance Forum 3 16 Nov 2002 01:42 pm
