Bad Spindal
Old 04 Oct 2011, 08:30 pm
spotman's Avatar
Question Bad Spindal
I need some help, just found out that my driver side spindal is out of round. I have a 2005 GT Turbo H.O. Automatic. What i would like to know can a spindal from any other PT Cruiser fit and work with no problems? PLEASE HELP with this. Thanx
Found this out due to me replacing the driver side bearing 2 times, the second time, just pushed the bearing by hand no press used.
Old 05 Oct 2011, 12:16 pm
UptownSport's Avatar
Default Re: Bad Spindal
There's a spindle in rear, in front, I'm assuming you're referring to the 'hub'?
Old 05 Oct 2011, 07:54 pm
spotman's Avatar
Sorry, It's the driver side front wheel hub assembly , but the spindal is bad..
Old 05 Oct 2011, 08:46 pm
There's no spindle in front.
You mean the knuckle, which holds the bearing and has steering arm cast in? Ball joint and strut bosses?
Old 05 Oct 2011, 09:29 pm
spotman's Avatar
Yes, that's it..
Old 05 Oct 2011, 09:57 pm
Gremlin's Avatar
I didn't realize the knuckle could even get out of 'round'... but there are a ton of them (used) for sale on Ebay: 03 04 05 06 07 PT CRUISER L. FRT SPINDLE/KNUCKLE on eBay!
White '03 GT. Mine since 2010. DIY work (read, budget): DIY cabin air filter, ball joint/control arm bushings/wheel bearing replacement, CV axle replacement, brakes, struts, K&N drop-in filter, oil pressure sensor replacement, Spark plug gasket replacement.
"But I don't want to go among mad people! Alice remarked. Oh you can't help that, said the cat, We're all mad here. You're mad, I'm mad. How do you know I'm mad? asked Alice. You have to be, or you wouldn't have come here, replied the cat."
Old 06 Oct 2011, 01:00 pm
About the only thing that goes wrong (because brake abutments bolt on)
is bearing spinning in steering knuckle's race.
Obviously, anything can break / bend in an accident.
You could see if someone would braze it up. It's been done.
Old 06 Oct 2011, 02:39 pm
It could just be the hub that is bent. Curbing it could have caused it, trying to beat it out to change a bearing (rather then press it out) can cause it (don't ask how I know this).
It is unlikely that the knuckle is the culprit. But as posted above, there are plenty on ebay if it is. A hub can be purchased at your local auto store.
-Greg
Old 06 Oct 2011, 03:47 pm
Really! Yikes!!
I pound these out ~ 2x month for use on Neons. They use early PT hubs so they can fit larger spline axles- Won't break @ dragstrip.
I have a tool special made for the purpose. (center pic)
Seems, if I understand correctly, his hub is bad but also the steer knuckle.
I have used early hubs if anyone has need. Later models no so much.
Old 06 Oct 2011, 06:19 pm
spotman's Avatar
Thumbs up Re: Bad Spindal
Hey, thanx to all you guys. The info is a really big help. Found one at the local yard and will be put on this sunday. Will be replacing the knuckle, bearing, hub and finish it off with alignment. Then back to having fun agian with this vert. Agian, thanx for the help.
want to buy driver spindal with wheel bearing abethedrifter Classifieds: For Sale/Trade 1 25 May 2010 03:18 am
