PT Cruiser Forum Car Videos
Car Rims
Wheel clearance problem ?
Old 15 Jan 2004, 11:45 pm
pt4u2nv pt4u2nv is offline
Default Wheel clearance problem ?
Put a set of 17" x 7" rims with 235/45 tires on to see what they looked like and to check the fit and was amazed at how close the tire was to the strut plate that the spring sets on. There was only about 1/4" between the tire and the plate. Is this normal and can it hit with any extreme movement in the front end. A few of my friends are running this tire combo but I am not sure they ever looked to see how close this is to the strut. The wheels are for a PT Cruiser so I assume the offset is right. Will this be a problem or will the tire stay this distance from the plate at all times. I am not sure of the mechanics of the strut suspension and what really moves and when.
Old 15 Jan 2004, 11:55 pm
IRPT IRPT is offline
pt4u2nv, I'm running 225/45's on a 17x7.5 inch rim and I have less than 1/4" space between the tire and the strut plate. I haven't had any problems. The 235/45's on the 17x7.5 inch rims would have been too much. You should be OK with the 235/45's on the 17x7 inch rims as long as you have some clearance.
2002 Inferno Red PT Limited
Mercedes Wiki
vB code is On
Problem with a wheel bolt Striker Wheels, Tires, Suspension 13 17 Aug 2006 05:27 pm
Wheel troubles on GT robinjoe Wheels, Tires, Suspension 3 24 May 2005 07:03 pm
I think I'm having a power steering problem! lumofny Tech & Performance Forum 5 18 Jan 2005 01:12 pm
New Steering Wheel at Jegs nhrapt Interior Accessories Forum 2 24 Feb 2004 01:03 am
Need help fixing a lug bolt. KurtPT Tech & Performance Forum 4 12 Aug 2003 06:03 pm
  Loans | Babb Fest | Compare | Credit Card Consolidation | Secured Loan
