Knocking sound from front end
Old 21 Jan 2012, 08:00 am
Default Knocking sound from front end
I have a 2001 Limited Edition, approx. 103,000 miles. Yesterday, I took the car out to fill her up and noticed a knocking sound coming from the front end. The sound seemed to stay in time with how fast I was going. Seems to be coming from the drivers side but cant say for certain. I know I need new front rotors, so I'm wondering if this is what it was. It was snowing too, so maybe something got into the bad rotors? Husband is going to look at it today, just wanted to get some advice. Thanks alot. Love this forum, always helps me out.
Old 21 Jan 2012, 09:07 am
Default Re: Knocking sound from front end
Usually the knocking sound comes from a front end suspension joint or worn bushing but sounds like that don't keep in time for how fast your going. Did anyone do any work on the brake system that maybe didn't tighten in down properly? If you know about the rotors, brake pads wold also need replacing usually. We could take guesses all day long but it comes down to someone inspecting the front end to find out where the noise is coming from.
On a larger note, have you had the timing belt and water pump replaced?
Old 28 Jan 2012, 04:51 pm
Loose lugs will make that noise!
Old 03 Apr 2012, 02:59 pm
wheelgarage's Avatar
That I need to check first.......good point.....
2005 Touring Black - Automagic....California Smog Legal
H&R Cup Kit | TSW Sakata 18x8 35ET | Nankang NS-II 235/40/18 | SPC front alignment cam - rear shim | Master Pro Rotors | Master Pro Ceramic F/R pads | Rebuilt Cylinder Head - Safety Valves and Guides | Felpro Head Gasket and upper rebuild kit | Fail-safe 195 degree thermostat | Mopar Waterpump...lol | 3rd radiator fan motor | Gates timing belt kit | WIX filters (oil, transmission) | Mobile 1 5w30 | Mopar ATF4 | Redline Water Wetter | K&N Drop-In | 4th Drive side Axle | Energy Suspension Torque Mounts | 3rd set of Torque Mounts...
Front End Knocking and Vibration arnsc Wheels, Tires, Suspension 11 10 Mar 2011 03:34 pm
Vehicle vibration and knocking sound over bumps MauiPT Wheels, Tires, Suspension 1 25 Feb 2011 06:42 pm
Knocking in front end. warmonger13 General PT Cruiser Discussions 4 26 Nov 2010 07:07 am
KNOCKING ON FRONT PASSENGER SIDE SUSSPENSION PATGAS Wheels, Tires, Suspension 2 11 Oct 2009 12:48 am
knocking sound mykelzy Wheels, Tires, Suspension 6 23 Sep 2004 09:51 am
