LCA question
Old 29 Jan 2012, 10:16 am
Default LCA question
2008 touring with about 75K miles... picked it up about two weeks ago and it has the dreaded cruiser clunk... shop replaced the passenger LCA and front end links, but said the driver's side was good.. Unfortunately, the noise is still there...This is my first Cruiser, so I don't know how things are supposed to look..
looking at the new LCA (passenger side), the bushing is solid, and there's a good half inch or more clearance between the LCA and the frame... on the driver's side, the LCA is flush to the frame and the bushing is sticking out the top... Is that right or should the shop have replaced both sides ?
passenger
driver
thanks for the help !
Old 29 Jan 2012, 11:58 am
Default Re: LCA question
Seems to me, if one side wears out, the other side can't be in too good of shape so you might as well replace both sides. Same with breaks, rotors and wheel bearings.
Old 29 Jan 2012, 12:07 pm
The driver side looks bad to me
Old 29 Jan 2012, 12:57 pm
UptownSport's Avatar
First photo is of a newly installed bushing (the 'blacking' is still on it,
you can see scoring where they pressed it in) and the second is of
a failed original equipment bushing.
Old 30 Jan 2012, 10:08 pm
Any chance someone could post a pic of a good driver's side bushing ? That would be a lot of help.
Thanks again
Old 30 Jan 2012, 10:43 pm
passenger side.
Old 31 Jan 2012, 08:56 pm
so it's safe to say the driver's side should look more or less like the passenger side ? not an asymetric design ?
Old 31 Jan 2012, 10:39 pm
Both sides should look the same...the driver's side is bad.
Old 01 Feb 2012, 07:40 am
Skyforger's Avatar
This a common issue with the bushings going bad? Mine is only at 39K, but I noticed a sort of popping/banging noise at low speeds over rough roads from the right side. The car did deal with nasty Brooklyn roads all its life though.
-Chris-
2003 Pontiac Grand Am GT Sedan - 152K
2003 Chrysler PT Cruiser Limited - 41K
2003 Mitsubishi Galant ES - 79K
2008 Cadillac DTS - 43K
Old 02 Feb 2012, 01:09 pm
Yes, this is common, all the way back to when the "Px" body was first made in 1993.
The bushings then were far too compliant even when new, they caused wobble and wheel hop when drag raced.
They quickly failed, too.
It seems Chrysler favored smooth, quiet ride over longevity and performance.
:question:daytime running lights!!!:question: jrs61282 Tech & Performance Forum 10 07 Nov 2010 10:53 pm
Luggage Rack question and trailer hitch question Patrick_Dickey General PT Cruiser Discussions 5 26 Apr 2009 09:19 pm
