lower torque strut
Old 21 Feb 2012, 08:44 am
Default lower torque strut
Hi everyone, this is my first post on this site. What a great site for PT lovers.
I'm thinking about replacing the lower control arms on the PT. It looked like a relatively straight forward job until I got to the part in my Haynes manual about removing the lower torque strut on the passenger side. Especially the part about adjusting the torque strut. From what I gather, the top torque strut and bottom strut bolts have to be removed ,then replaced. Then make sure the distance between the engine mount bracket hole and the shock tower bracket point is 4.7". If I don't disturb the upper torque strut will it affect the alignment of the engine mount in relation to the shock tower bracket? This looks like it could be a nightmare considering the designation in tenths of an inch and no tolerance.
Thanks for any insight you can give on this.
Whew! I'm tired already.
Wayne
Old 21 Feb 2012, 03:37 pm
rcktpwrd's Avatar
Default Re: lower torque strut
I never measured or adjusted the torque struts and haven't had any problems. But it really isn't that hard to measure and adjust.
I don't think you will have any issues if you just pull the lower on off to do the suspension work.
Joel
www.rcktpwrd.com
What is the torque strut adjustment procedure? ChampageCruiser Feedback and Support 0 03 Sep 2010 12:21 am
lower torque struts adjustments cruizinla Tech & Performance Forum 5 14 Oct 2009 10:09 pm
Strut rod nut torque Espresso Wheels, Tires, Suspension 2 08 Jun 2005 04:08 pm
Upper Torque Strut Installed Mean Green Turbo Performance 1 24 Jan 2005 12:03 pm
Strut bolts torque spec's? silky Wheels, Tires, Suspension 4 21 Jan 2004 11:17 pm
